17-18 LPH thats just crazy,, if i flog it,, 13-14 at worst,,, if i drive normal,, 10-11,, im prity bang on 1L for 10km, and thats with the MAF disconected,![]()
buggered if i know!
after i thought i had gotten somewhere with my fuel consumption issue in the D2 it appears i havnt
replaced every sensor except the map sensor...
the last 2 tanks showed 11-11.8L/100k
this tank i got 17.49L/100k
and that was with the wife driving all of it bar one 80klm trip on sunday.
so ive just changed out number 2 injector as it was showing -7 to +7 on the nanocom while the other 4 showed -3 to +5..
oh and im off to QLD on wednesday, hope im not looking for fuel every 500k's
stupid brilliant motor
cheers phil
Out of curiosity, have you looked at/changed the crank angle sensor ?
I'm not sure if this would affect your fuel economy but was the cause of my TD5 showing excessive injector +/- figures on the nanocom.
its not underpower is it, have you tryed updating your ECM, unless you have a chip?
I couldn't find a pattern to the +/- injector readings, they were all prone to large readings (anywhere from +/- 5 to 17); a much different scenario to that of yours if you were only experiencing a single injector out of whack.
