Results 1 to 10 of 15
Thread: Rear / Boot Door will not open
    Aug 2009
    Brisbane, Sunshine Coast, Gladstone, QLD
    I am having issues with the rear door on my D2. I can not open it from the inside or the outside.
    I did a search on the forum and when I eventually got it open, pulled out the lock and cleaned it etc. As soon as I closed it again it is stuck.
    I recently took the spare wheel of the back the door seems to be tighter since then, almost as if the door lifted without the extra weight.
    Does anyone have any ideas on how to atleast get it open. I can not remove the lock again until then.
    Adelaide - Torrens Park
    It is possible to get into the load space and pull the door rubber clear of the door. Then you can operate the child lock mechanism. Doing that a few times sometimes frees them up.
    Aug 2009
    Thanks BigJon, I did try that when I had the lock out of the door.
    Cleaned it, moved all the parts numerous times etc.
    I might just need a new lock.
    Shaker Guest
    Are you sure the lever in the outside handle isn't sticking?
    Aug 2009
    I have the internal door trim removed, so can manually move the lever on the lock itself and it still will not release.
    Does anyone know if there is some way of opening it from within the door frame?
    maintain some upwards and outwards effort on the door.
    jiggle the handle upwards
    it'll come eventually
    Bacchus Marsh Vic.
    If you think the door has lifted slightly try and push down on the handle trim. Maybe get some one to push down from inside.
    Plan B, go for a drive on a rough road and try and shake it a bit.
    I "wash" mine in CRC and when dry use graphite powder(lasts about 14months).Repleced the bolts to hex heads also.
    It's now a annual maintance item.
    Cheers, Kyle
    The Good Oil.
    When did you last visit?
    Aug 2009
    Well I have tried lifting it, pushing it, hitting it with a rubber mallet and no change.
    I will just try and find some rough roads for the next few days and see if it comes lose.
    Bacchus Marsh Vic.
    Quote Originally Posted by CJT View Post
    Cycle the lock(with key buttons or snib handle) also, seemed to help mine.....eventually
    Cheers, Kyle
    The Good Oil.
    Melbourne, AU
    Sounds like you have tried all the traditional tricks. FYI when my lock failed it was replaced under warranty so they do fail completely.
    _________________________
    1996 D1 V8 - gone
    2002 D2 Td5 ES- gone but still running elsewhere
    2013 D4 SDV6 HSE - gone
    2023 Defender 110SE D300
