Page 1 of 7 123 ... LastLast
Results 1 to 10 of 64
Thread: 1st Traxide Discovery 4 specific dual battery kit
    Queensland
    Hi folks and this is an update on my D4 Dual Battery Kits.
    The D4 kits on my web site can be fitted to either D3s or D4s but are specifically designed for D4s up to MY13 models.
    But with the auxiliary battery compartment being available in the MY14 D4s, you now have a choice of either a D4 specific DBS kit, supplied with a battery tray, or you can now fit any of my D3 kits or the D3 Triple Battery Kits in a MY14 D4.
    I have just upgraded all my D3 and D4 kits, making them almost completely Plug-N-Play which means they are easier and quicker to fit and there is a much more informative set of installation instructions supplied with each kit.
    These new instruction contain for more photos of the installation techniques use to carry out a kit fitting, make the whole installation a much simpler job.
    For more info on my D3 and D4 kits, please check out my web site.
    Sunshine Coast, QLD
    Looks good to me. Just for feed back, as for 2nd battery in rear, I would prefer removable and something that can be tied down. No Rush, won't be getting the D4 until 2nd half of this year.
    Thanks.
    Discomaniac.
    Queensland
    Hi Discomaniac, all going well I will have 4 to 6 new D4 kits by the end of this coming week.
    These kits will be set up for a number of combinations of Dual Battery Systems for the D4 but will also fit the D3.
    I’ll list everything about the new kits here by the end of the week.
    The biggest hold-up has been the installation instructions, and so far I’ve take over 200 of the D4 and at least 50 are in the new instructions
    BTW, I am also working on a battery box, with extras, that while being developed for the D4 ( and D3 ) should be of interest to anyone looking at using a removable battery set up.
    Feb 2010
    Disco 4 Auxilary Battery
    Hi,
    I wish install a dual battery system in a D4 due for delivery mid year.
    I've looked at your post wrt D4 battery install and found it very informative.
    However, there is no mention of an auxilary battery in the engine compartment of the D4. Is this intentional?
    Are the Dual battery kits you've planned similar to previous D3 kits with back load space sockets etc as per the SC80-LR Plug & Play Kit + the LR Full Power Cable Kit?
    Agro
    Queensland
    Hi AGRO, if you decide to move the module in the auxiliary battery compartment, then any of my D3 dual battery kit can be used as the set up is identical.
    I have produced the D4 kits for dealers and people who decide against moving the module and choose to fit a battery in the rear cargo area and/or want to charge camper trailer or caravan batteries while on the move.
    So AGRO you have a number of options and for those with a D3 and want to install a larger auxiliary battery in the rear cargo area instead on a small auxiliary battery under the bonnet, then any of the D4 kits can be used.
    Subiaco, Perth
    Thumbs up Disco 4
    Next week is the big day for delivery of my Disco 4. I am looking forward to seeing your setup for a battery mounted in the rear of the vehicle. Have my first trip planned to leave Perth 01/06/10 and need a set up by then, hope you can help.
    Drivesafe, I've been meaning to ask...
    if you're setting up for people with caravans are you providing any current limiting in the unit for people who are running gels in the van as deep cycles?
    The medium size gels are starting to make an appearance in some of the campers with low power demands.
    One of the snorkers at work bought a camper that had a gel battery to run the radio and lights, he cooked the battery by coupling its charge socket to the charge socket on the back of his 4b when it went flat. The battery's been replaced under warranty and he's been advised to only charge it with the supplied regulator or a 30w solar panel but he wants to be able to top up on the move.
    Queensland
    Hi Blknight, and I usually get asked about what batteries to fit where and I go the other way and just advise them to fit either flooded wet cells or if there not likely to look after the batteries properly when the're not in use or if the batteries have to be mounted in a confined space I recommend the use of AGMs.
    I never recommend gel cells, just don’t like them. They are way to finicky.
    While I dont normally recommend them either I think I've found the niche that they are going to fill for the foreseeable future
    in a small camping trailer/caravan as a stand alone 12v supply intended to run a handfull of led lights and a car radio charged up by a small panel or a plug pack.
    I was surprised to learn that its cheaper ro get a gel in the same capacity of an oversized motorbike battery than it is to get the flooded version.
    Subiaco, Perth
    Disco 4
    Hi Drivesafe,
    On the 4th of Feb you said that an auxiliary battery system would be ready soon, any progress?
