Results 1 to 8 of 8
Thread: P38 Head unit
    Jan 2010
    Narangba
    P38 Head unit
    I want to take the face plate of my radio head unit, there are two small narrow slots but I can't seem to feel any kind of lock/tab/release etc behind them, suggestions.
    Rushy
    What year model?
    For pre-99 models, see my pics here:
    radiolcd
    Jan 2010
    Narangba
    Thanks Ron but mines a 2001 and it is different but thank all the same.
    Rushy
    Douglas Park, NSW
    Quote Originally Posted by Rushy View Post
    mines a 2001
    What spec? HSE/SE/lower?
    Some base models had a locally fitted Eurovox unit.
    Jan 2010
    Narangba
    Hi Scouse, it's HSE spec
    May 2008
    Hi Rushy - if you can post a pic of the unit it will make it a lot easier for us to give useful suggestions.
    Cheers, Paul.
    Most likely it's an Alpine. there are 2 keys required. They slot in each side of the radio chassis from the front.
    Search RAVE "Special Service tools" section...page 133 of 140 using terms "radio removal" The Land Rover tool is LRT-86-006 there's a diagram and they're easy to make. I made mine from the black plastic base of a green Woolies grocery bag... LR proabably specify aerospace grade titanium...
    You just need a couple of slivers a few mm wide and about 75mm long with a square section nibbled out a few from one end of each key. You slide the keys in horizontally at the top of the radio one each side... "nibbled" end first and facing "out" -the nibbled out section catches a tab : then just "pull" the keys out gently ...with the radio!
    Jan 2010
    Narangba
    Thanks for the info gents,
    Rushy
