Results 1 to 10 of 19
Thread: Electrical connectors are hard to find :(
    Nov 2008
    Greenwood WA
    Unhappy Electrical connectors are hard to find :(
    Hey guys I have a Series 2 and I was trying to locate the little double female type bullet connectors which are used for the lights to link park, indicators etc.
    I located a parts supplier in England but they wanted $3.50 for each one and I need about 10 I think.
    I have attached some pictures to help identify them and I would love it if someone could point me in the right direction. I have check the parts suppliers thread in this section and I couldn't locate these on any of them.
    THX in advance.
    Jan 2009
    Queenscliff, Victoria
    I found them a little hard to find so made my own.
    Cut some strips of heavy tin or copper foil, about twice as wide as the bullet connector length. You might even be able to use a tin can if it's not too thick.
    Roll the strips from each a couple of times around a shaft about the same diameter as the plugs. I used a medium size phillips head screw driver.
    You'll need to experiment to work out the right strip length based on the foil material you use.
    Put the rolled connector inside some scrap electical outer or sheath. eg left over from stripping some heavy duty cable. Make the sheath a bit longer than the length of the rolled foil connector.
    Squeeze the connector a little so the plugs make a good connection when inserted.
    Thats about it. With a little experimentation you can make up some pretty good connectors.
    I bought the complete stock off my local Auto One. I was wondering what to do with them.
    Feb 2009
    Warrimoo, Blue Mountains, NSW
    Quote Originally Posted by matpoli View Post
    Hey guys I have a Series 2 and I was trying to coate the little double female type bullet connectors which are used for the lights to link park, indicators etc.
    Search for "bullet connectors" on ebay, there's about a squillion of them.
    Peter
    Quote Originally Posted by peterg1001 View Post
    Peter
    Ahh, but do they fit the old style?
    Nov 2008
    Greenwood WA
    What exactly did they package them as at auto one?
    Or you could just send me ten
    Jan 2008
    Gladstone, Queensland
    They were loose. I bought their complete stock of original roll in type crimp connectors like this:
    (not the modern plastic insulated crimp connectors) and all their bullet connectors. They wanted to clear them. Unfortunately, they gave no discount.
    Douglas Park, NSW
    Vintage Wiring Harnesses will have them. It's been a while since I bought any so I don't know what they're worth now.
    Or try a wrecker of older English cars. Minors & Minis are full of these connectors.
    Mar 2007
    Seaford, Near Franganistan, Victoria
    If they are the same as early Range Rover, I have some. They are yours for the postage cost.
