Results 1 to 10 of 19
Thread: That's what I call an engine!!!!!
    Back down the hill.
    Maximum power: 108,920 hp at 102 rpm
    Maximum torque: 5,608,312 lb/ft at 102rpm
    The Wartsila-Sulzer RTA96-C turbocharged two-stroke diesel engine is the most powerful and most efficient prime-mover in the world today. The Aioi Works of Japan's Diesel United, Ltd built the first engines and is where some of these pictures were taken. It is available in 6 through 14 cylinder versions, all are inline engines. These engines were designed primarily for very large container ships. Ship owners like a single engine/single propeller design and the new generation of larger container ships needed a bigger engine to propel them. The cylinder bore is just under 38" and the stroke is just over 98". Each cylinder displaces 111,143 cubic inches (1820 liters) and produces 7780 horsepower. Total displacement comes out to 1,556,002 cubic inches (25,480 liters) for the fourteen cylinder version.
    Some facts on the 14 cylinder version:
    Total engine weight:
    2300 tons (The crankshaft alone weighs 300 tons.)
    Length:
    89 feet
    Height:
    44 feet
    Maximum power:
    Maximum torque:
    Fuel consumption at maximum power is 0.278 lbs per hp per hour (Brake Specific Fuel Consumption). Fuel consumption at maximum economy is 0.260 lbs/hp/hour. At maximum economy the engine exceeds 50% thermal efficiency. That is, more than 50% of the energy in the fuel in converted to motion.
    For comparison, most automotive and small aircraft engines have BSFC figures in the 0.40-0.60 lbs/hp/hr range and 25-30% thermal efficiency range.
    Even at its most efficient power setting, the big 14 consumes 1,660 gallons of heavy fuel oil per hour.
    A cross section of the RTA96C:
    The internals of this engine are a bit different than most automotive engines.
    The top of the connecting rod is not attached directly to the piston. The top of the connecting rod attaches to a "crosshead" which rides in guide channels. A long piston rod then connects the crosshead to the piston.
    I assume this is done so the the sideways forces produced by the connecting rod are absorbed by the crosshead and not by the piston. Those sideways forces are what makes the cylinders in an auto engine get oval-shaped over time.
    Installing the "thin-shell" bearings. Crank & rod journals are 38" in diameter and 16" wide:
    The crank sitting in the block (also known as a "gondola-style" bedplate). This is a 10 cylinder version. Note the steps by each crank throw that lead down into the crankcase:
    A piston & piston rod assembly. The piston is at the top. The large square plate at the bottom is where the whole assembly attaches to the crosshead:
    Some pistons:
    And some piston rods:
    The "spikes" on the piston rods are hollow tubes that go into the holes you can see on the bottom of the pistons (left picture) and inject oil into the inside of the piston which keeps the top of the piston from overheating. Some high-performance auto engines have a similar feature where an oil squirter nozzle squirts oil onto the bottom of the piston.
    The cylinder deck (10 cylinder version). Cylinder liners are die-cast ductile cast iron. Look at the size of those head studs!:
    The first completed 12 cylinder engine:
    Wonder If Justin could do a valve grind on it?
    Williams West Aust
    I once had the pleasure of visiting the engine room on a container ship.
    The donk is HUGE!!!!
    Surprisingly it was as clean as a new cars mojo!!!!
    More like something to run a power station than a canoe!!!
    Andrew
    DISCOVERY IS TO BE DISOWNED
    Snow White MY14 TDV6 D4
    Back down the hill.
    Andrew
    A couple of Cummins KTs can cover that..........in a small town.
    Have you ever been in the generating room of an indigeonus settlement over your side? Quite impressive too.
    I can read the text, but can't see the pictures
    Think I've come across this before though.
    Melb. Vic.
    Sounds impressive. Cant see the pics either.
    Mar 2009
    Derbyshire UK
    I could e-mail the pic's if you wanted to see them, it is awesome.
    ps thanks Ian
    Nov 2006
    cardiff ,NEWCASTLE.
    Yep i would like to have a look thanx Grockle
    1969 LWB S2a yellow, gone
    1972 LWB S2a 5 DOOR wagon coming & GONE
    1973 LWB S3 green Sadly GONE
    1977 LWB S3 tabletop building
    1992 disco BOINGY BOINGY
    My landrover doesn't leak oil , IT SWEATS POWER
    JASON & KAREN
    Andrew
    Actually, the motors used to run diesel or small gas power plants are usually the same engines used to run ships of the same power, so not surprising.
    One of the interesting visits I did in the early sixties was to the old power station in Roma. This contained a virtual museum of engines, starting with a four cylinder spark ignition gas engine of about 100hp, installed to run on producer gas from wood chips in the 1930s. They increased in size up to the most modern ones, two 1,000hp eight cylinder NA diesels from the 1950s - about fifteen feet high, and twenty feet long, they had been converted to run on gas straight from a nearby gasfield.
    Williams West Aust
    No I havent Ian.Only the best I would expect.
    Andrew
    Mar 2009
    Derbyshire UK
    Quote Originally Posted by banjo View Post
    pm me your e-mail address then Jason
