You know that's illegal right ?
(Just in case you didn't).
 Master
						Supporter
						Master
						SupporterH All, I have just remover the front and rear swaybars from the 130 defa. The flex seemed a little restricted before, so i was just wondering how much more travel people think i will achieve now. I am heading bush on the weekend so i guess i will find out but i was just after anyones experiences/thoughts????
Cheers Jim
gone
1993 Defender 110 ute "Doris"
1996 Discovery 1
current
 Master
						Supporter
						Master
						SupporterYeah but you should see it flexup.... If only i could have the best of both worlds. Does any one know if there are sway bar disconects that you can get for the 130??????
Ditched the sway bars in my 130, best mod I ever did, more articulation and smoother ride. However, if you have standard suspension you will need to replace the dampers with firmer units to control body roll.
 Wizard
						Wizard
						 Master
						Supporter
						Master
						Supporter| Search AULRO.com ONLY! | Search All the Web! |
