Originally Posted by
nelpd96
Well just to raise this again, I got the red triangle this weekend on my 2010 3.0 D4. Similar circumstances as outlined, towing on the Hume for around 90min and cruise cut out going up a hill. Limped into Mittagong and did a hard reset and some other stuff but the Engine System Failure warning remains. Disconnected the brake controler just to be sure and made it to Wondilly River Station without incident, coming home no problems till around Picton about 90min of driving again and I am struggling to make 80km/hr up a slight rise with the camper trailer on.
Parked the car up while I unpacked and then took it for a drive after around an hour and it was back to full power or very close to it. Have it booked into Graeme Cooper tomorrow for a once over. I can only hope that the PCM upgrade has not been done and it will be a simple fix. I will update with the findings.
Paul
Paul, if you don't get any joy check the plastic inlet manifolds. My 2010 3.0l did something similar and was OK for a while after clearing the fault but after a few days it would fault again immediately after clearing faults. It turned out to be a cracked inlet manifold (we think due to a broken T piece in the vacuum pipe on top of the engine, which meant there was no waste gate). It took my guys a long time to find the problem and it is not cheap to fix. I replaced both manifolds on mine in case the second one also failed soon.
Bob
2010 D4 3.0TDV6 SE, ediff, LLAMS, 5 x GOE wheels, LT285/60R18 BFG K02's, GOE Compressor Guard, LR Tank, Mitch Hitch, ECB Bull Bar, Kaymar Rear Bar, Traxide, Safari Snorkel.
2019 Discovery 5 SD6 SE, 20 inch wheels, 275/55R20 Nitto Grappler G2 tyres
