Thread: Oil Temperature Gauges
    Tassie/Perth
    Is it worth having seperate gauges for the transmission and transfer case?
    I'm looking at which gauges I want in the mud dash at the moment. I've had a lot of trouble in the past with very warm transmission/transfer cases and I want to monitor the temps. But I'm wondering if I'll get the same reading from both areas considering their proximity to each other?
    Chris
    North Avoca
    Oil temperatures
    You might find this thread useful.
    Engine Oil and Transfer Case Oil Temperatures
    Mellow Yellow
    No matter what the problem - there's a solution. You've just got to find it.
    2013 Discovery 4 TDV6 3.0
    2015 Defender 90 - The TARDIS (Gone)
    2003 Defender 110 - The Yellow Peril (Gone but remembered fondly)
    2001 Discovery II TD5 (Gone)
    1986 County V8 (Gone)
    Jul 2003
    Quote Originally Posted by cewilson View Post
    Chris
    Hi Chris,
    As the previous post was useful my only advice is don't buy a Prado:
    Can we laugh at the new Prado again?
    Mahn England
    Ex 300Tdi Disco:
    defenders come with a built in warning device for the TCase/gearbox.
    its called the hand brake. lift up your trouser leg and rest your calf against the handbrake. When you cant keep it there any more you've gotten to the point that you need to slow down.
    Tassie/Perth
    Thanks to all. I'm going to guess that I can get away with the one gauge on the transfer case.
    BTW - my other vehicle is a Prado
