Results 1 to 8 of 8
Thread: rivets - correct ones for the body
    Feb 2005
    pop rivets are starting to pop off the body work of my defender, i have about seven missing and three about to pop
    what are the correct rivets buy, i am guessing they are aluminium and blind
    diameter and draw would be nice
    Freestyler Guest
    You should be able to buy rivets at any GOOD hardware store. I used aluminiums one on my county when I converted it to an Extra Cab. This was so I didn't get corrosion in the ally body due to indifferent metals. There are "water proof" or "water resistant" rivets. They go in the same way and you don't need a special tool, just a good pop rivet gun. They are sealed at the blind end. Most are open and you can see the other end of the pin,
    these you cannot therefore don't let the water in. In theory anyway.
    Tim
    Weeds old son
    Not 100% sure, but I reckon 3mm x 8mm would do the trick. Why not buy a selection. That way you'll get some to fit. They're cheap as chips and always come in handy.
    I've done a couple on mine and it's just a case of ratting through the tray for the right size.
    JDNSW's Avatar
    The ones I have used are Able Cooke TA 6-4 sealed aluminium rivets. These are 4.8mm diameter (3/16") and to rivet thickness 4.8 - 6.4mm. In some places the next size shorter may be neater, but the longer ones will work perfectly well.
    These should be available from any decent hardware store or from specialist fastener suppliers, although probably only in packs of 100.
    East-South-East Girt-By-Sea
    1.20 MB
    Make sure you count them. There is sure to be someone who'll check!
    Apr 2002
    Godwin Beach 4511
    32.38 MB
    JD has it to a tee...
    which rivets have let go kelvin?
    2007 Discovery 3 SE7 TDV6 2.7
    2012 SZ Territory TX 2.7 TDCi
    Yinnar South, Vic
    Quote Originally Posted by Freestyler View Post
    Tim
    Pics of the extra cab?
    Feb 2005
    Quote Originally Posted by incisor View Post
    umm, some rivets around the rear light assemblies, the one just infront of the rear wheels and a couple on the bonnet (bonnet mounted spare)
