Can I do this and does it matter what wires are joined of the two?
I feel silly contradicting Tombie, but Im not sure if I am....
I just replaced the right front wheel sensor in my D2a. To do so, I bought the replacement part with the "long lead" that bypasses the two pin plug above the wheel well, and goes direct to the SLABS. I made a perforation in the rubber gromit above where the main harness goes through the firewall behind the pedals, and passed the cable through there. Then I used an old chippy trick. I got a piece of yellow tongue (long piece of plastic that joins particle floor boards), and threaded that behind the centre console through the wiring harness....tied to that was my wheel sensor lead, pulled it through. Then using Rave, determined the pins in the C505 connector in the SLABS that where for the right front, clipped those off 5cm from the connector. Soldered new cable to those wires. Put connector back in, reset ECU using Nanocom. Problem solved. All up, probably takes 20 minutes, plus whatever time it takes you to take of wheel, calliper, and disk. (In my case, 2 ****ing hours). If you are asking which of the green wires you solder to...no, it doesnt matter.
Hi - i am due to suspension convertion with long travel shocks,i've pulled and repositioned the wires as far as i could - no more slack on the sensors wires for future mods.
Where can i find-order such an extension,i googled and couldn't find anything..
Cheers.
PS
I had a Renault Kangoo 4x4 and had ripped rear left sensor wire once,dealer was asking 180 euros so i used-made-soldered a 10cm extention with plain wire - nothing special and worked like a charm,is something different-special with Disco wires(resistance or something else)?
Last edited by fatman; 20th May 2010 at 02:57 PM. Reason: Added the Kangoo thing..
The genuine part is long enough to do what you want...I reckon I had at least 2 ft spare, and I have a 2 in lift....if you have no fault in yours, and, more importantly, if you have some abs wire, then it should be able to be done. The system DOES work on resistance though, so using a different gauge wire/resistance wire may not work....and yes, the genuine part was not cheap.
http://www.expeditionexchange.com/ca...cat=294&page=3
go with the above i did it easy plug in and play cheap to and from the makers of D2 abs system wabco
cheers kelvin
Rudolf that sounds like a plan, since I want to go to at least 70 mm lift.
