Page 1 of 15 12311 ... LastLast
Results 1 to 10 of 150
Thread: 3.9 to 5.0 litre
    Lambo Guest
    3.9 to 5.0 litre
    Hey Guys,
    I have a 1995 Disco with a standard 3.9 V8 and auto box in it. I have been considering dropping a 5.0 litre Holden V8 and Turbo 700 gearbox in. Anybody ever tried this and can tell me what are the potential pitfalls.(probably heaps).
    Lambo
    Crafers West South Australia
    Quote Originally Posted by Lambo View Post
    Hey Guys,
    Lambo
    Um, $$$$$
    steve_35 Guest
    http://www.realsteel.co.uk/section1.pdf
    Dont bother going GM unless you have lots of money and a lot of time
    Its a lot easier to stroke the Rover V8 out to 5.0 link above
    And you dont need an engineers approval cause its the factory engine
    Yinnar South, Vic
    Yea don't do it, cause I've never tried it
    Downfall is, no adaptor for the auto to transfer case, can mount the 5L infront of the ZF, it'll handle it stock, but if you plan on upping the HP after that, it won't take to well and are big bucks to build tough
    They are an easy engine to use in a conversion
    I'd suggest 6L 4L80E
    Kingston, Tassie, OZ.
    Quote Originally Posted by rovercare View Post
    .....You would
    JC
    Goolwa SA - but top ender forever
    Brilliant combo, if you can afford it the 6L80E would be more brillianter
    99.87 MB
    What did the 4L80E come with? Was that the 6 litre tranny or an HSV part etc?
    Slunnie
    Jan 2010
    Newman WA
    The 4L80E you need comes from a Suburban . Im doing the same , sticking in a Holden V8 engine , The rover 5 litre is gutless pile of crap compared to the Holden and by the time you have built it will cost more than the Holden V8 . and last a quarter of the time/Kilometers . THe only way you get any sort of Half decent power out of any rover V8 is to supercharge/turbo it . As has been stated forget the T700/4L60E they simply dont fit . (easily)
    Jul 2008
    400HPONGAS wrote,...
    Are you talking about the Holden 4.2 or 5 litre V8? From what I have read, both and especially the former were regarded as being rubbish engines. Poorly designed and in need of a rebuild after 100,000 miles or less. There was also a problem with the 5.7 litre Gen III where piston slap resulted in large numbers of engines requiring a rebuild while under warranty.
    A well maintained Rover V8 will run for more than 30 years so add another and that will drive you till your driver's license is revoked.
    Ron.
    99.87 MB
    Quote Originally Posted by RoverP6B View Post
    Ron.
    Somehow I don't think so re the holden V8.
    Slunnie
