14th June 2010, 06:20 PM
a little more power from my 2.25 petrol
my series 3 2.25 is a little bit tired and i was wondering if anyone knows some cheap and easy ways to just get a little more from the old girl?
any help appreciated
14th June 2010, 07:47 PM
14th June 2010, 08:08 PM
A set of fresh rings and bottom end bearings and then throw a s13 silvia turbo on the side of it.
14th June 2010, 08:44 PM
#4
Shave 125thou off the head,rebuild both the carby and dizy and fit a set of headers. Pat
14th June 2010, 10:09 PM
#5
16th June 2010, 11:09 PM
#6
Regrind the cam to a similar profile to the 2.6 6cyl. all valves will then open 5 degrees sooner and close 5 degrees later, allowing the engine to breathe. If you're using ULP, have the dizzy recalibrated (take some vaccuum advance out of it). Get a high compression head, fit electronic ignition for a better spark, fit good quality leads. Use the Zenith 36IV carby. Keep your tyres at 50psi on the road.
If that sounds too expensive, PM me and I could sell you a whole SIII with a motor rebuilt 15,000miles ago by the British army, with the above mods already done, plus extractors and a double barrel weber carby (the Zenith comes as a spare, but the weber doesn't do nearly as much as the cam regrind did).
