Results 1 to 9 of 9
Thread: HELP: Found this under my Defender!
    Jun 2007
    Question HELP: Found this under my Defender!
    I just swapped out my Brake Vacuum Pump as the old one was kaka...
    and well I found this on the ground under the Defender...
    It is a rubber plug, 14mm High, flange is 16mm dia, and plug if 10mm dia, stamped MOSSPLUG 6
    Does anyone know where it came from?
    I did not pull anything like this off when pulling out the air filter to do the vacuum pump swap. I just undid bottom hose and back hose clamps on air filter and clamp on hose to vacuum pump.
    I'm Stumped where it came from ???
    Avoca Beach
    Well to me it looks like a caliper bleeding nipple cover. When new all LRs have them on all the nipples.
    Regards Philip A
    Apr 2002
    Godwin Beach 4511
    32.43 MB
    x 2
    2007 Discovery 3 SE7 TDV6 2.7
    2012 SZ Territory TX 2.7 TDCi
    Bracken Ridge, Qld
    x3
    (I don't really know I'm just trying to appear that I do).
    gone
    1993 Defender 110 ute "Doris"
    1996 Discovery 1
    current
    It'sNotWorthComplaining! Guest
    Regards Philip A
    in other words..... Caliper nipple bras?
    Jul 2007
    jan juc
    Quote Originally Posted by It'sNotWorthComplaining! View Post
    i think that it is one of those 4 rubber plugs that go in to the block that sit on the ridge just above where the top of where the vacuum pump sits .I think they put them there to plug moulding holes in the block.
    Scarborough, QLD
    did someone say nipples?!
    NSW far north coast
    Quote Originally Posted by PETER S View Post
    I agree.
    Jul 2008
    Haha.. ok.. ill av a guess. Slave cylinder bleed plug? Or.. Maybe the off your wheel arches?
