 Originally Posted by
lambrover
				I need to get stronger axles. I was out playing today and got stuck in a rut
I need to tell you that I have been getting some tyre wear, took the car into the wheel alignment guys and the camber is out of spec, I had already cheaked the kingpins and bearings and they where good so it just leaves the axle housing being bent.
So I need a straight housing and I will brace it and I then need to fill it with goodies.
My car is a county so has better CV's, can anyone tell me how good the standard county CV's are. I want to build a new front end with a locker so if I fit the locker and new stronger axles how long will the CV's last.
 Mate, The county cv's AEU2522 are about the strongest you will get other than paying a fortune for Ashcroft ones. What you need is to get hold of a front axle assembly from an RFSV, and put stronger axles like Jack Macnamara or maxi drive type. You wont bend that axle housing. Other alternative is to straighten and strengthen your existing one. Isuzurover (Ben) has a thread on one he did-check it out. Add a 4pinion carrier like the RFSV or 6by has or a trutrac or Quaife and you're in business. Tim may be able to help with a replacement housing. Might be up that way over the next few weeks - will give you a call when I know dates.....Brian
				Cheers......Brian
1985 110 V8 County
