Page 1 of 6 123 ... LastLast
Results 1 to 10 of 59
Thread: Boge leveller
    Hay Point
    Boge leveller
    Anyone had their boge leveller for a 110 reconditioned. Is there a place in Qld that does them,approx what cost and does it last.
    Cheers......Brian
    1985 110 V8 County
    Jan 2010
    Newman WA
    You could always swap it for the later model defender setup , I here its much more reliable and never needs reconditiong , LMFAO !!
    Wheelers Hill, Melbourne
    I'd run around without it & see if you can tell the difference!!
    After all, the Army 110's don't have them.
    Hay Point
    Quote Originally Posted by DeeJay View Post
    I removed it about 10 years ago because it was knackered and I had a set of Polyairs I wanted to fit but they didn't last very long and now I am that much older and appreciate a softer ride. I have acquired one to fit but would like to have my original reconned to keep as a spare. You can notice the difference when you remove it - it is like an extra shockie on the rear and does help on corrugated roads as well as assisting with load levelling.
    Cheers......Brian
    1985 110 V8 County
    Hay Point
    Quote Originally Posted by 400HPONGAS View Post
    What do they look like. Any pics?
    Cheers......Brian
    1985 110 V8 County
    lokka Guest
    If i were you and wanted a smother ride id fit twin shocks to the rear it will give the same effect and be alot easyer and cheaper to set up and keep in service .
    I will be doing this mod to my 130 county soon as i want the smother ride when both laden and unladen as it is now unladen its ok but i know i can make it better with more dampening
    SA, Newton
    The load leveler is great, load up the county drive down the road and she’s back to normal ride height, nice soft springs, she floats down the road and you don’t get tossed around as much on the tracks.
    I suspect that anyone who knows how to rebuild these are either out to pasture or what a fortune. Open it up and have a look yourself, there cant be much in them.
    NB there is no latter model, they just changed to stiffer springs and a bum in the air attitude.
    Apr 2002
    Godwin Beach 4511
    32.43 MB
    apparently ww shock absorber reconditioners down this way still do them
    2007 Discovery 3 SE7 TDV6 2.7
    2012 SZ Territory TX 2.7 TDCi
    Avoca Beach
    Try here
    Reconditioned Parts
    easy Huh!
    Regards Philip A
    Quote Originally Posted by clean32 View Post
    ........ Open it up and have a look yourself, there cant be much in them.
    Do NOT follow this advice unless you know exactly what you are doing. They contain (or should) gas under high pressure, and a wrong step in disassembling them could be a real problem.
