Results 1 to 10 of 22
Thread: Help please
    Qld.
    Help please
    I'm fitting a new water pump (and thermostat) this weekend - spent this afternoon trying to get the shot pump out - and all by myself, I'm nearly there!
    What I've done so far....
    1) Slacken dynamo mounting bolts and rotated dynamo inwards ( to get the fan belt off),
    2) removed the upper radiator hoses
    3) removed the thermostat housing from cylinder head complete with outlet pipe, inlet elbow and joint washer
    4) removed the fan blade
    So - all I need to do now is remove the fan pulley then unbolt the actual pump.
    My question is this - once the fan blades are off - does the fan pulley just pull off too? I can't see any bolts to undo - the workshop manual doesn't show any either - but I tried pulling it forward and it wouldn't budge.
    Do I need to pull harder or is there something I'm missing?
    2007 Defender 110
    1993 BMW R100LT
    dmdigital's Avatar
    Good to see the workshop manual instructions haven't improved in detail in 54 years
    Qld.
    I'm borrowing Numpty's real workshop manual - it's a heap better than the book I have. But yeah - to dumbarses like me - there could be a little more detail.
    But answering my own question - I think I might just need to pull harder - the manual lists the bolts I took out of the fan blade (parts 46 and 47) as being, "Fixings for fan blade and pulley" - so I guess I'll just try again tomorrow.
    2007 Defender 110
    1993 BMW R100LT
    Qld.
    But please - any experts please confirm I just need to pull harder!
    2007 Defender 110
    1993 BMW R100LT
    clean32 is offline AULRO Holiday Reward Points Winner!
    SA, Newton
    not a S1 type. but normaly yes
    is there enough room to pull the pump out with the radiator in ?
    Qld.
    Quote Originally Posted by clean32 View Post
    Yep - even with the shroud still on.
    2007 Defender 110
    1993 BMW R100LT
    SA, Newton
    Quote Originally Posted by Scallops View Post
    ok then just hit it with a hammer
    Timj is offline Wizard Silver Subscriber
    Brisbane,Qld.
    Hi Dan,
    Usually things like that just require a little more persuasion . Sometimes two screwdrivers, one from each side levering it off can help. Or you might need a puller which is three arms that hook under the pulley and a bolt that tightens up against the centre and pulls it off. If you don't have one they are pretty cheap from autobarn, supercheap or repco or you could come and borrow one if you like.
    Tim.
    Gumnut - 1953 Series I 80"
    Poverty - 1958 Series I 88"
    Arnie - 1975 710M Pinzgauer
    Pump removal
    Scallops
    using your largest screw drivers
    2 would be good
    slowly work around between the housing and the block, using them as a lever
    very gentle taping with a copper hammer will help to brake 50 odd years of rust
    a little heat around the edge of the housing may also help
    gently gently catchy monkey
    it will come away, no need to remove radiator and cowling
    Ian
    smurf village
    i agree 2 screwdrivers
