Results 1 to 10 of 22
Thread: Front Seals/Steering Lever Removal
    G'day all! I finally have a couple of days to work on my wagon and intend to tackle the front end. After taking off the stub axle, I found the Axle Half Shaft, etc. is completely covered in grease. This of course leads me to believe there was a leak and the diff oil was working its way out and someone took the easy way out.
    I am keen to get the system back to the oil lubricating system it is designed for. A few queries:
    -Is it possible to take off the steering arm lever without using the special tool 600590? I am hoping I can simply take off the four bolts that hold it to the housing and then line it back up when needing to put it back on. This would also allow me access to the swivel pin bearing and shims.
    -Should I plan on replacing the swivel pin bearing while I have this apart? I will order all the parts at once, so any feedback is appreciated.
    -It looks like a fair bit of extra work to get to the SWIVEL PIN HOUSING TO AXLE HOUSING Gasket R232413. Does this typically leak? If not I'd rather not take off the swivel pin housing to get to it.
    -Here is the list a local group has as their front swivel kit. Anything else you reckon I need?
    R232413 GASKET SWIVEL BALL TO AXLE HOUSING
    FRC2906 FIBER THRUST WASHER FOR UPPER PIN
    R539742 UPPER RAILKO BUSH
    R217268 LOWER PIN BEARING
    RTC3528 SWIVEL HOUSING SEAL
    R576583 UPPER PIN
    R531433 LOWER PIN 'O' RING
    R277289 STUB AXLE GASKET
    R531001 (4)LOCK TABS FOR UPPER & LOWER SWIVEL PIN BOLTS
    R217353 LOCK TAB WASHER FOR WHEEL HUB NUTS
    R231505 DRIVE FLANGE GASKET
    RTC3516 'O' RING FOR DRIVE FLANGE (FRONT 109")
    RTC3515 FELT SEAL BETWEEN AXLE/DRIVE FLANGE (FRONT 88")
    R219098 METAL HUB CAP
    -There's heaps of grease in there and the UJoint is covered in grease. I will just clean this up the best I can......Any tips?
    Thanks for any help you guys can offer! I am hoping to get the parts ordered tomorrow so I can get this sorted by the end of the week.
    JRW
    yes its a good idea to replace the bearing. but if its not showing signs of excessive wear pitting or other damage you can let sleeping dogs lie providing you can achieve the correct preload on it.
    to replace the bearing you usually wind up having to put it in a press which means hiring the hulk to hold up the front of the vehicle to the press so you can press the bearing out OR removing the ball housing from the axle in which case, yes you need to replace the gasket in question.
    no, that particular gasket doesnt normally leak unless you mess with the bolts, (see above answer) and it can be omitted and replaced with a good quality formagasket.
    Thanks mate! It seems like for the sake of a few bolts and a gasket that I should probably just take off the ball housing, have the bearing pressed out/in and just knowing I did things correctly. It seems like this shouldn't radically change the amount of work which I need to do overall.
    There is a mechanic's shop who has a shop near here. Is it pretty reasonable to think that any mech around should have the gear to press out the bearings? I also need him to punch out/in the inner races for the wheel bearings.........
    Any idea about this query I had? "-Is it possible to take off the steering arm lever without using the special tool 600590? I am hoping I can simply take off the four bolts that hold it to the housing and then line it back up when needing to put it back on. This would also allow me access to the swivel pin bearing and shims."
    Thanks again!
    JRW
    JDNSW's Avatar
    JDNSW is online now RoverLord Silver Subscriber
    Quote Originally Posted by neophyteguy View Post
    Thanks again!
    JRW
    This tool is used to disconnect the steering arm from the tie rod end. Suitable pullers can be bought from most auto supply places, or you can simply loosen the nut and give the side of the eye a good whack with a hammer, which will usually release it.
    Note when removing the arm that one bolt is a special fitted bolt which should be kept in the same location.
    Thanks John!
    So are you saying that I will need to take off the steering arm from the tie rod end in order to perform the work or was your response more of an FYI?
    I was hoping I could undo the four bolts that connect the steering rod arm to the housing and then turn the steering in order to clear the arm from the housing area?
    EDIT: John I realised it is possible to get the work on the diff sorted without removing the ball joint.........Now it seems as though I will have to take it off any ways so I can adjust the shims!
    JRW
    Last edited by neophyteguy; 6th September 2010 at 08:44 PM. Reason: Worked on Vehicle and Sorted it out......
    So today I was able to get the swivel pin housing broken down and cleaned. Everything went pretty well overall. However, I once again have a few questions as I will be putting things back together on Thursday.
    Thanks in advance for any help you guys can offer!
    - The manual states that the resistance to the rotation of the swivel pin should be 12-14 lbs "after having overcome inertia". What exactly does the overcoming inertia blurb mean?
    - I am assuming that it is best to grease the half shaft bearing, swivel hub oil seal, swivel pin bearing, and the inner and out wheel bearings. Can someone confirm this is all that actually needs to have grease applied?
    - The manual states 1.75L of oil to replenish the front diff. Would you recommend putting a bit more/less than this in as everything is new in the system?
    - A couple of the studs on the bottom of the swivel hub pulled out when I removed the nuts. Is it best to put something like "aviation sealant" on these when I put them back in? I noticed the holes actually go all the way through the hub and could potentially leak.
    Thanks again in advance for any responses!!
    JRW
    what the rotational effort means is after you have started the housing moving and while it is still moving the resistance should be between 12+14LB measured at the ball joint socket of the arm.
    its always a good idea to pack all bearings with grease appropriate to the application based on the oil used
    80/90 or 85/140 or heavier use normal wheel bearing, high temp/high pressure grease
    10/30-20/50 use Vaseline
    10/30 or lighter and I tend to pack the bearings by heating up a tub of engine rebuild lube and dropping the bearing in then fishing it out.
    nope fill the sections up to the normal levels then check them after a few KM. dont forget that you will need to pack the wheel bearings with grease and provide a reserve of grease if you intend to utilise the one shot grease in the swivel hubs.
    I wouldnt use hylomar #4 on the studs, I would be using loctite 262 to locate the studs and letting it setup for at least an hour prior to putting the oil in.
    Thanks again Blknight!
    Are you suggesting to use the one shot in the swivel hubs? I had planned on just using the same oil as the diffs, but happy to follow the advice of others......
    JRW
    this has been covered several times, like all things it depends on which evil you wish to deal with when it comes to maintaining your rover.
    I favor oil filled hubs.
    Dec 2008
    Hi,
    Back to one of the earlier questions, the tapered roller bearings nearly always get pitted in the straight ahead position. I have never had too much trouble getting them out and replacing them.
    A fishing scale or spring balance is ideal to measure resistance. The "overcome inertia" comment means ignore the spike to get it moving. Leave the big seal off til its right.
    Andy
