Results 1 to 10 of 16
Thread: just got a L series freeloader
    Hunter Valley
    purchased a 2000 L series Freelander last week. 160K on it. Did the timing belts today. tell you what the man that thought it was a good idea to put the crank locking pin there wants shooting.
    When I did my first timing belt I couldn't find it so did a risk assesment of the crank actually moving - not likely but still marked it in case it did - it never did and I will have to do it again in a few weeks.
    I have to replace the first piece of exhaust pipe at the same time so I might even stand a chance of finding it this time.
    The last time I did the belts I only did them and not the tensioners/pullies etc. I think I will do them this time. What do you think? I will also do the serpentine belt as well - any additional bits that should be done as well as the belt?
    Also did you move the engine to the passenger side of the engine as the book suggests? When I did mine I thought that was too much hard work so just undid the drivers side engine mounts and jacked the drivers side up when doing the top and lowered it when doing the bottom - was OK but piggy fingers had trouble getting into the available space. I also ground down a small socket set to get inthere as well.
    I have been putting the job off but it is now 2,000km overdue so I need to get in and do it.
    Hunter Valley
    The timing pin hole is between the IRD and the block near the crank sensor. its only small. the pin is about 1/4" diameter. You cant get you hands in there, has to be fitted with a magnet and a small pry bar as a screw driver will need a bend in it. It would be easy with no IRD.
    I replaced everything 2 belts 2 tensioners and a idler. My thinking is its done 160k and they have spun around many times and a lot cheaper than a head if the belt comes off. It wasn't that expensive either $415 for all belts, all tensioners/idlers, full filter kit, sump gasket and clutch slave cylinder bracket.
    No didnt move engine. Jacked it up and down to get to bolts and uses a 1/4 sockets. Im lazy, so I took the tricky option. It took me about 2 hours to fit the front belt and change the tensioner and idler.
    I assume you did the injection pump belt as well?
    At 160,000km you are also at the critical distance for VCU failure. With the original IRD you have a ticking time bomb that will require checking very often. Mine failed back in early 2006 taking out the IRD (rear drive pinion unmeshed due to bearing failure but thankfully was able to drive it OK in 2wd until I could assemble parts for repair. I put in a matched IRD/VCU out of a low km TD4. Overall the final drive is a bit higher than original so I cruise at lower revs but 1st is a bit higher when off road.
    Lake Macquarie. NSW.
    Garry, would that also apply to a 2001 FL1? My understanding is that certain changes were made in early 2001 and the later models are not as prone to this problem!!!!
    That is my understanding - actually from the first update in 2000. I would however be doing a VCU check as part of my service program. In my case - every 5000km and when I suspect something - has tested OK on every occasion.
    Hunter Valley
    Yes did the injector pump belt aswell.
    The IRD in it is the updated version, so it has had 1 at some stage. I checked the VCU using the RRC VCU method and it passes.
    Hunter Valley
    Quote Originally Posted by Ausfree View Post
    Your Freelander will have the updated IRD, The update was fitted to all V6/TD4. VCU still needs checking as they can still fail and do eventually wear out.
    Other than the VCU/IRD issue my Freelander was been a top car that has been incredibly reliable - it has now done 270,000km. The interior is almost as new,no squeaks or rattles. The heater dumps a little coolant once every 6 months but has done so for the past 6 years so I am not going to fix it. Likewise the front right CV clicks but it has done so for the whole 6 years I have had it (110,000km) and has not got any worse so again will leave it until it needs work (I have had a spare waiting to go in for 4 years).
    It was a shame that the petrol models and the early IRD issue damaged the reputation of the car so much because the diesels were so much more reliable than other landie products of the time - my Freelander was certainly far more reliable than the V8 disco that I also drove.
    Hunter Valley
    I know thats why I bought one. After working in a dealership for almost 10 years all ive done to a L series besides all the bulletins and IRD's is 1 head due to broken timing belt, 2 turbos, injector pump and a few sets on glow plug. They are a great engine, people say the TD4 is more reliable but Ive done less work on a L series.
