Results 1 to 10 of 27
Thread: UHF CHANNEL BANDWIDTH
    Sussex Inlet. N.S.W.
    With the start of the new channel structure will it be legal to still use older 40 ch. sets or will their channel bandwidth be too great? Jim
    Jim VK2MAD
    '17 Isuzu D-Max
    Jul 2003
    Yes it will still be legal and the current sets will still work on the existing 40 channels. The new additional 40 channels are being "slotted" in between the existing frequencies.
    From this useful site: UHF CB Australia - News - Repeater Locations - History - Sales & More
    Frequently Asked Questions
    Will my old UHF CB radio still work when the changes take place?
    Yes, You existing UHF CB radio will still work after January 1st 2011
    Will my old UHF CB radio interfere with other channels?
    It is possible that old UHF CB will interfere with new channels but you would need to be very close to another radio to create a problem
    Can I talk to someone on a new UHF CB radio with my old UHF CB radio?
    Yes, You will be able to talk to another person using a new UHF CB radio provided they are on one of the current 40 channels, if the other UHF CB radio is on one of the newly allocated channels then you will not be able to talk to them
    Will I notice any changes when talking on a new UHF CB radio with my old UHF CB radio?
    Yes, You will notice that the sound will be distorted but you will be able to talk to each other
    Mahn England
    Ex 300Tdi Disco:
    Feb 2009
    It is my understanding that the use of the 'current' 40 channel units will not be supported beyond 5 years and after that their use will be illegal. Also, because of the narrower channel spacing the 'signal energy' will be significantly less and the end user will perceive this as lower volume (ie you will have to turn the sound up).
    KarlB
    miky Guest
    Quote Originally Posted by KarlB View Post
    KarlB
    And the source of this "understanding" is?
    Feb 2009
    Quote Originally Posted by miky View Post
    Here is the link to the draft standard: http://www.acma.gov.au/webwr/_assets...ndard_2010.pdf .You will see, pursuant to s7, that after 1 Jan 2016, older equipment will be deemed to be noncompliant. Also, all new equipment sold 6 months after the new standard comes into force must be compliant with the new standard. The standard is still a draft and there may be changes, but I wouldn't bet on it. I have seen nothing to suggest that it will not commence on 1 Jan 2011, as indicated in the draft.
    KarlB
    miky Guest
    Thanks for the link. Just what I was after.
    Central Queensland
    i'm yet to see a valid argument for changing the existing setup
    Hamish71 Guest
    It doesnt really matter, does it. if you need a radio to use now, then pretty much you are stuck with a 40 channel set up.
    At some stage in the future though, this set up will be redundant, and you will need to replace it.
    So, do you really need one?....or can you wait?
    miky Guest
    Perhaps the question to ask your supplier is: can the radio be programmed for the new channels?
    For what it is worth... the Icom 400Pro can. I have a 400Pro.
    As far as I can see the Icom 440 can't. I don't have one.
    Looks like the GME 36xx and 38xx radios can. I have a 3840.
    If any one can provide a list of radios that can be programmed it would be good.
    Also, when will the "new" radios become available?
    Feb 2009
    I would be highly surprised if the major manufacturers are not poised for the release of new models and are just waiting for the finalisation/release of the of the new standard by ACMA. They will be holding back a little, hoping to get rid of old stock I suspect, but as soon as one of them makes a significant move, the rest will quickly follow. Unless something falls over with ACMA, the market will see all the new models in the first quarter of 2011, I am sure. I am holding off.
    KarlB
