Results 1 to 10 of 30
Thread: Nanocom READALL firmware.
    As some of you know reading back your TD5 ecu will be stoped with the nanocom and the file wont be saved.
    Ive rewriten some of the firmware to stop this process happening and help you all save your files.
    Ive added the needed firmware upgrages to my Dropbox file share folder.
    If you dont have Dropbox or have not herd of it then follow the link, register, download and install it and you will see the files you need.
    Dropbox is a web based file storage place a little like Rapidshare.
    http://www.dropbox.com/referrals/NTE0OTk3MjY1OQ
    Pete
    Nov 2007
    home at last - Port Macquarie NSW
    i dont understand the problem you describe with the nanocom
    stupid me :/
    When some people buy a Nanocom tuned file it has a file extention of .Tun or simlar this is locked to a partucular vin number and will not let you use it again on a spare ecu. The file needed to use on a spare ecu is a .Map which is unlocked.
    So, if you have tuned file on your TD5 and you want to add to a spare ecu you must re save it first as a .MAP, but you can not because the Nanocom tells you the file is protected and can not be saved
    This removed the nanocom protection procedure and lets you resave the files as a .map
    Ive also added a file called MapConvertor1_01.exe to the shared folder that will let you recreate .Tun files locked to a particular vin and Nanocom ID if you so wish.
    Pete
    Ellendale Tasmania.
    I have installed drop box and cannot get the MapConvertor1_01.exe file
    Baz
    Quote Originally Posted by B-A-S View Post
    Pete
    Cheers Baz.
    2007 BMW R1200GS
    Pm me your dropbox email address and I'll add the needed permissions to the folder.
    Pete
    your email is added.
    Pete
    Jun 2010
    Holland
    Hi Pete
    Can i have the files as well?
    regards,
    Hylke
    Dropbox mail: hylkegroeneveld@gmail.com
    Added
    Pete
    Jun 2010
    Holland
    Thanks pete,
    Installing as we speak.
    hylke,
    May 2008
    Mudgeeraba, QLD.
    Hi Pete,
    Tried to download files. Folder appears to be empty.
    Thanks,
    Dave.
