Results 1 to 10 of 23
Thread: hitches
    Aug 2010
    brisbane
    hitches
    Hi everone just drove back to brisbane with the new d4 3lt se sensational vehicle 2 questions what is the best hitch to buy and where from in brisbane and same for a brake controller cheers Roger
    Heathcote Junction
    The oem hitch on the D4 is much improved over the D3.
    This means you should only have to buy the tongue insert & ball.
    Believe it or not I found the oem insert to be cheaper than a 3500 kg rated one from hayman reece!!!
    I have retro fitted a D4 hitch & insert/tongue for my D3.
    I am not sure which is the best brake system however be aware that if they are not wired right they can be problematic.
    Chuck
    Feb 2010
    Mount Martha
    Roger, I have stuck with the standard D4 hitch set up. Its fine with my boat and trailers. Not yet towed anything and found the OEM a problem.
    Cheers, Craig.
    Sydney, Australia
    If you plan to tow off road then you will need a mitch Hitch.
    Sep 2010
    east gippsland
    Hi Rogngab,
    I did alot of research into hitches for the D3 and found the mitch hitch to have the best/most approppriate specs, however, Whilst i am more than just a little handy with the tools i decided that i would fit it myself and it was not as easy as they would have you believe. I was able to fit it however what should have taken no more than an hour ended up being 3 hours. I would advise you get someone else to fit it if you are not to handy on the tools, ie let them have the headache LOL
    PS if you want to more details on the problem i had just PM me.
    good luck
    Gladstone
    I use a Rapid Hitch on my D4.
    Feb 2010
    Mount Martha
    As mentioned earlier, I have no problem with the standard D4 hitch, however I did put the Mitch Hitch on my D3 and found it to be a great advantage over the OEM. Had mine colour coded. Looked good.
    Cheers, Craig
    Feb 2010
    Mount Martha
    Worked out how to attach the full size pictures.
    Here is a photo of my ex D3 with the colour coded hitch.
    Quote Originally Posted by Disco4SE View Post
    No you haven't - where is the pic?
    Feb 2010
    Mount Martha
    Bugger...........thought I had it worked out
