Check out Car Builder Solutions - NF Auto. One-stop Shop for Parts, Tools and Accessories for the Car Builder. Neil and Matt Foreman.. There'll be something in there that fits.
Peter
Hey guys,
I'm fitting a round smiths heater to my 2A and need a valve to control the coolant flow.What was originally fitted to do this?
The heater has 1/2" hose ends poking through the firewall.
Some pics would be great.
Cheers Eric
 Master
						Master
Peter
 Swaggie
						Swaggie
						Any decent parts shop will have a catalogue of after market heater valves.
URSUSMAJOR
try Four Wheel Drives
they have a pretty good catalog available for download. They may have one in there
The original stood a couple of inches high on the head, with a screw down control on top, side outlet. No remote operation.
Heater valve part no. 269562
You can also mount it at the front of the head, which is where mine is. Mine has a broad flat lever handle instead of a wheel
 YarnMaster
						YarnMaster
						If you find out what the thread is in the head - probably 1/2" BSP - you can check out the taps in the plumbing section of a hardware store.
I found one for my S1, which is the wheel type, for $12
Cheers Charlie
This might help as there is no original remote operated valve.
See second post
http://www.aulro.com/afvb/technical-...ypass-lpg.html
