Results 1 to 10 of 17
Thread: Supercharged classic rangie. Boring
    Warburton, Victoria
    Went for a ride in a 95 classic rangie yesterday that was blown and had haltec management on it. Sadly it was disappointing. Very. It was a very nice conversion with a 4 litre in it. Blower was off a Holden V6.
    Won't say much more but it needed to breath better. Performance wise. Good off the line. But that's it. My VE V6 ute flogged it and My ute weighs in at 2500kg. Mmmmmm so sad
    Hamish71 Guest
    But I bet it SOUNDED GREAT!
    Ringwood, Vic
    I'm guessing that was the one at Freds?
    When are you going to tell us all about your new defender?
    D4 SDV6, a blank canvas
    Warburton, Victoria
    Nope sounded like a normal stock rangie. No blower noise. No exhaust noise. Yes wardy. The one at freddies
    Warburton, Victoria
    What new defender!!!!!! Lol
    Only thing I have new is my ute and that's now done 30k. So sad
    Ok I'll post a new thread on the pos fender
    NSW , Pennant Hills
    So Clarkie , should I hold back and not Bolt up my M90 Blower on the 3.9 with worked heads. Will I be disappointed ?
    Goolwa SA - but top ender forever
    Quote Originally Posted by Disco_owner View Post
    from all I have read, the M90 is to short and can create pressure differences and can bugger the engine apparently the better one is the M112 as it is longer and gives an even pressure across the intakes?
    dunno if it is true or not but I have read that in several different places now
    Bit of gentlemanly discourse on Pirate about blowers and Rover motors atm (down the page, below the RRC surgery pics) here:
    New RockStar Fab project vehicle - Page 7 - Pirate4x4.Com Bulletin Board
    Gold Coast, QLD
    The fueling issue I beleive may have something to do with the standard 14CUX ecu having no extra fueling above 4800rpm.
    I think you will find the main problem in the install you test drove was all to do with the engine management system.
    It's very easy to set them up poorly, yet ever soo difficult to set them up well.
    If a supercharged classic can't at least sorta keep up with a 2.5ton ve ute, then i'd be looking beyond the charger and the motor (assuming it's running a descent amount of boost, over 6psi).
    Was it an auto or manual?
    Grimace
    I rule!!!
    2.4" of Pure FURY!!!
    Warburton, Victoria
    Auto. Running haltec. If it breathed better it may go harder. I'd expect it to turn the tyres. But sadly. No. Mind you. My VE is about 220kw
