Results 1 to 10 of 13
Thread: Converting US power packs
    Scarborough, QLD
    I have a couple of chargers for GPS devices that have the US plug prongs (like Aussie, but not slanted).
    They're both rated for 110V-240V 5A. Is it possible to simply bend the prongs around to fit in an Aussie GPO, or is this beyond ghetto and just dangerous?
    I have done that but you run the risk of cracking the plastic and the plug does not want to stay in the socket as the pin goes from the Aust angle at the end of the pin to the US flat at the plastic and tends to pop out.
    miky Guest
    You can buy an adapter. Jaycar, Dick Smith etc. Maybe JB HiFi etc.
    Aug 2009
    Brookfield Melb. Victoria Australia
    Hi Im sure you can get an adapter, I have seen them for Australians travelling to the UK so that their Mobile phones, Hairdryers etc can be used Im sure the same would be available in the US?
    Garfield, Victoria
    Quote Originally Posted by adonuff View Post
    In the US - yes, but he is in Queensland! What you are thinking of for Australians travelling to the US is Aus 3 prong female to US 2 prong male. Not as common as UK/EU, because the voltage is different in US (& Japan).
    What Ranga needs is a reverse adapter, which is Aus 3 prong male to US 2 prong female . I have seen so called "Universal Adapters" in Jaycar, I think, and maybe Dick Smith. These should do the trick - albeit a bit clumsy, but certainly better than bending the prongs.
    Lionel
    Yinnar South, Vic
    Just cut the end of and fit a 3 pin plugtop, they come with instructions that any fool could follow
    Garfield, Victoria
    Quote Originally Posted by rovercare View Post
    I think Ranga's talking about a "wall-wart". You can't just "cut the end of (sic) it" without partially destroying the unit!
    If it's an inline type charger where you plug in a cable, well fine, but otherwise an adapter is the only safe way.
    Lionel
    Jul 2003
    I just ordered an adaptor for aussie to asia from DSE
    But here is one for you:
    KORJO Multi Reverse Adaptor Set | Dick Smith Online Shopping
    Mahn England
    Ex 300Tdi Disco:
    Crafers West South Australia
    Quote Originally Posted by Ranga View Post
    Works on soft plastic plug tops, done it a couple of times. Wouldn't do it to a plug pack though.
    Got the adaptor you need gratis free with a charger from China (ebay), pm me if you want it. I just bent the pins on the cord you see.
    May 2010
    melbourne
    Personally I just bend them with a small shifter. Never had any problems so far, the prongs may sheer slightly but that depends on the plastic.
