Results 1 to 10 of 15
Thread: Hole identification on 2.25 engine required, please
    drifter Guest
    Hi team
    I recently sent my engine away for a rebore and a cleansing dip. It's back now and I am preparing to reassemble it.
    One of the jobs done was to replace the cam bearings (cos the dip wasn't too kind on soft metals).
    Anyway, in having a look over the block and re-acquainting myself with what fits where (it was away a long time) I have discovered two holes that I can't identify.
    They go from just above the plate that the fuel pump attaches to to the no.3 and no.4 cam bearings so I suspect they are a part of the oiling system.
    I have looked through all of the pictures I took of the block before I sent it away and cannot see what, if anything, was attached to these holes. They have no thread so I am assuming some kind of plug goes in them.
    Can anyone identify them, please?
    Here are a couple of pics. The first one is of that side of the block, showing the holes just to the left of the distributor mount and above the fuel pump mount:
    In this second pic, I have zoomed in a little closer:
    If you want to see a bigger copy of the pic, click on it.
    All input gratefully received.
    Near Seven Hills, Sydney
    Just checked, both petrol and diesel 2.25s of mine, the holes are present and not plugged in any way. Pretend they don't exist
    drifter Guest
    Thanks, Mark, for the message and for actually checking it out on your own engines.
    I guess mine must have been full of gunk that was cleared when the block was dipped.
    Are you not concerned that they expose the 'outside' of the cam bearings?
    To be honest, I didn't look close enough to see if they were blind or not. I will await the answers of the more experienced members on that one too.
    Having said that, the cam bearings shouldn't move and would provide a reasonable seal to the outside world so I don't expect they'll cause any problems not being plugged.
    from memory they are the bolt holes for the IP timing pointer on a diesel
    drifter Guest
    Thanks Dave
    So, maybe, they just tapped the diesel ones?
    cant remember, never had an OEM timing marker for setting up the pump and I dont have my dead tree edition of the manual/parts books here that deal with the series stuff.
    Feb 2009
    Warrimoo, Blue Mountains, NSW
    Quote Originally Posted by isuzutoo-eh View Post
    Same on mine, and the same goes for the third hole in line with them to the right of the distributor.
    Peter
    Cessnock NSW
    Mystery Holes
    G'day All, I'm sure you are talking about the 2 holes in the block behind where the distributor fits and above where the fuel pump is mounted, if so these holes had a purpose (note had) thats where the oil gallery is cross drilled so as to allow oil around the cam bearings, cheers Dennis
    ps if you cleaned all the crud out you should be able to see the bearing shell.
    drifter Guest
    Quote Originally Posted by Dinty View Post
    Yup - I can clearly see the bearing shell.
    So - we just leave them open?
