Results 1 to 10 of 11
Thread: Full 300tdi Disco running gear into 2a 109 ute
    Jun 2008
    Castle Hill, Sydney, NSW
    G'day all, just thought I'd share my latest ridiculous idea and see if anyone has had any experience with it.
    The idea:
    Buying a CHEAP(ish) 300tdi Disco (with a buggered body/interior) and giving my 2a 109 ute a SERIOUS upgrade! Full running gear swap all the way through from the engine to the tyres, coil-spring suspension included
    Reasons:
    Far greater fuel efficiency, diesel reliability, disc brakes, better ride, power steering (for the missus), ability to install air-con, and freeway driving without my overdrive whine I'm sure I'm leaving plenty out too!
    The obvious:
    Just to answer the "JUST BUY A DEFENDER" replies in advance, we love our Bruce and love working on him.
    We're not afraid of some good fabrication, long hours and planning.
    We're not interested in hearing how crazy we are (believe me, we know!)
    Yes, I'm well aware this is a large and complex project.
    My questions:
    Has anyone ever done this?
    Can anyone see any MAJOR MAJOR MAJOR problems?
    Can anyone see any reasons why this couldn't be engineered?
    And yes I know I'm talking about putting coils on a leafy, and the engine and gearbox will need new mounts, and that I'm going to have to work out something for the steering..........
    I'm looking more for the less obvious
    Jun 2008
    Perhaps the most efficient way to tackle this is to create a list of issues/tasks.
    I'll kick things off:
    New engine/gearbox mounts
    New suspension mounting points, including new outriggers (to use factory disco trailing arms)
    New propshafts of correct length (as disco is 100in wheelbase)
    Flares for the wider wheel-track
    Fuel return lines to the tanks
    Panhard rod mount on chassis
    Id like to keep the series look front-end if i can, which may be do-able as due to the 9in longer wheelbase of the 2a over the disco, I could mount everything just a little further back and maybe even keep the factory disco rear propshaft...... provided that the length of the radiator, 300tdi engine, gearbox and transfer case can fit between the series grill and the chassis crossmember behind the transfer case..............?
    Lostkiwi Guest
    Would it not be easier to mount the the 2a body strait on to the disco chassis?
    There would be a lot less fabrication involved
    Crafers West South Australia
    I see your case, a Disco chassis would have ADR's applying, so no go. An early RRC chassis would be my choice for a donor chassis if you did it the easier way (a 100 inch special). Otherwise just enjoy picking every bracket off the Disco chassis and welding it on to the series chassis.
    Narrogin WA
    Anything is possible - somewhere on this site is a S3 (I think) which has had the 300tdi fitted with all of the upgraded drive-train. I am pretty sure that in the UK you can buy coiler chassis for series cars, so there is probably heaps of info on the web.
    My advice is to contact your licencing authority and tell them what you want to do and ask for their advice - I always find that "asking for advice" is the best way to approach people in authority In WA they encourage anyone to do that, which seems to be a sensible approach before spending any money on a project.
    Good luck, keep us posted on how you get on,
    Cheers Charlie
    Jun 2008
    Yeah, I'm not interested in using another chassis, it's gotta be Bruce's chassis and body. I've got no problem with taking all the brackets off the disco, that's what I had in mind. My first step after these holidays will be to go and have a chat to an engineer in sydney and see what the go is.
    I'll have a search tonight to see if I can find that series 3 with the full running gear conversion, that'd be a great starting point!
    Jun 2008
    I found mention of this conversion on a series three, but couldn't find a thread on it. Can anyone else find it?
    Jul 2010
    Birmingham England
    i don't really know too much about a full conversion especially with the 300tdi running gear
    but one thing i do know is you will have to move the injector pump side engine mount on the chassis(i'd say offside but i'm not sure if you lot drive on the wrong side of the road)
    you'll have an interesting time connecting up steering linkages from what i understand if you use the disco axles (not to mention having to weld on spring perches in the correct place), you'll also need custom length props and the disco gearbox has a "veeerrry" long bellhousing which will probably put the gearstick under your elbow
    now just to clarify things i've only owned landrovers for two years but i've been modifying my little 88" from the day i bought it, that is now fitted with a 200tdi which bolts in on the original series box and straight onto the original mounts..
    i've also fitted 3.54 diffs (not axles) from an early disco/range rover as they're 10 spline and stuck an overdrive on the back of the box, 11" backplates (single leading shoe) off a salisbury rear axle onto my front axle, parabolic springs and 1 ton shocks all round...
    i think it drives and stops brilliantly but i've not driven another to give it a fair comparison ...
    i'm now in the process of rebuilding a 1965 109 utility, this one is getting a 200tdi engine that will be fitted with a 300tdi exhaust manifold/turbo (to clear the chassis rail) and i'll be changing the diffs again, 4.3:1 ratio this time to see if i prefer them (would really like 3.9:1 tho) and another overdrive ...
    both of these conversions will return somewhere in excess of 30miles to the gallon as long as i'm not thrashing the motor, my 88" easily sits on the motorway at 70mph even on Deestone Extragrips (7.50x16) and i think i've touched 90mph when on the same size tyres but road orientated tread pattern and freewheel hubs disengaged (took a long downhill run ) i sat comfortably on the m/way the other day towing a dolly with a ford escort on it at 55-60mph (legal towing speed here) dropped the escort at Manchester then took the scenic route back (damn stupid satnav)so i didn't hang about, i reckon we did just about 200 miles on no more than 3/4 of an underseat tank of fuel (i also had a slight fuel leak from my injectors where i'd had to dismantle it all to get the water out of my bores the day before, i sank it in the river)...
    i very much doubt it's worth the effort of dropping in the disco or even a defender gearbox due to the amount of messing about with crossmembers, prop shafts and the trans brake even with 5 gears i doubt you'll match my top ratio in my 88"
    oh and yes i do offroad this 88" as well as use it as my daily driver, 2 years on a tired S3 gearbox and it's not gone bang yet, i've also not snapped a halfshaft but that could be the 3.54s protecting them
    p.s.
    300tdi axles use 24 spline diffs so you won't even have the cheap ratio experiments that i can do, i'm not sure if you'd be able to fit early 200 halfshafts and 10 spline diff
    East-South-East Girt-By-Sea
    1.20 MB
    You won't be able to get the 300Tdi engine and transmission into the series chassis and still retain the front body profile without removing the cross member behind the gearbox. You will then have to do some major mods to the firewall and tunnet cover and may then find that the Disco gearstick comes up through the middle seatbox.
    The power steering box, will want to sit where Bruce's front cross member currently sits (think stage 1) and where will you be fitting the radiator?
    BTW: the Rover 4.3 and 3.9 ratio diffs mentioned by NiteMare are possibilities but are getting as rare as hens teeth in Australia, and the Rover car enthusiasts who may still have them are very unwilling to part with them for Land Rovers. You also lose the 1st gear crawler ratios if you up the diff ratio. Remember Australia's rocky terrain is very unforgiving on Rover diffs and Series axles, particularly on a 109.
    Jul 2010
    Birmingham England
    ok just another possibility if you wanted to use 3.54 diffs would be to use a 109 salisbury axle under the rear and fit the diff out of a 110 salisbury and stay with the rover axle on the front with a disco/defender 3.54, only other thing you should need then would be the shorter rear propshaft to match the salisbury axle
    the "weak" point then would be the series gearbox
    which ever way you modify there is always going to be a "sacrificial" part in the drivetrain as very little is going to stand up to constant abuse, any offroad sport requires pretty high levels of maintenance/parts replacement which only lowers with less challenging obstacles/events or serious money being chucked at it
    just to restate i'm only learning about landrovers only having owned mine for two years (i've three and one for spares) and i listen to the guys that i believe have had the time and interest to experiment more than i have, so there are many things that i can get wrong ...
    thankfully there are lots of them on these forums that will jump in and correct me when needed
    p.s.
    i know it's expensive but you can still get crown and pinion gears brand new in almost any ratio you want if your budget stretches to that extent, i think £400 Sterling (for a self build) to do a pair of diffs here
