Results 1 to 10 of 24
Thread: Disco headlining
    hardlines Guest
    Disco headlining
    Hardlines asks: Has anyone got a DIY solution to glue-ing up sagging headlining in a Disco Series 2 Td5?
    As you are new here, I'll be gentle.
    The subject has been covered many, many times. You would be wasting your time.
    Search is your friend.
    As a starter, try here: http://www.aulro.com/afvb/good-oil/4...d-linings.html
    Two Rocks WA
    Sorry just had to
    Range Rovers Have Charactors inside them
    LROCWA Ex member 23 years
    1971 Series 2A
    2004 Discovery2a V8 Auto
    2003 Discovery2a TD5 Manual
    1982 4door man (sadly now gone)
    1989 Vogue auto
    2011 TDV8 Vogue
    What would life be without a Rangie?
    Sep 2010
    Qld
    Quote Originally Posted by hardlines View Post
    The hardest part would be removing and refitting the roof lining. Regluing the actual fabric or replacing the fabric is relatively easy once its out. Sorry I have no answer on removal specifically for a discovery, however you would normally need to remove or lower the front and rear seats to give you room to move, pull out all the plastic trims that hold the lining in place, disconnect the interior light, rear view mirror etc, all pretty basic to work out as you go, just remember to be gentle with plastic parts because they can be brittle from UV rays and will break if forced.
    Once the lining is out, use a spray adhesive which works like a contact glue and restick the fabric, allow to dry and reinstall. If you want to go new fabric, just trim to size after it is glued. It is a big job but if you are patient will cost less than getting it done by a trimmer. You can do a dodgy quick fix by stitching through the fabric and into the card with a needle and thread but it doesn't really look good or last well.
    Basically if you have some time to spare and have a couple of cans of spray glue you can do a pretty fair job, or look at pulling it out and taking to a trimmer to save the cost of the remove/refit which would be a couple of hours of labour. Good luck.
    Quote Originally Posted by pfillery View Post
    I reiterate.
    You will be wasting your time.
    Search and see that's the general consensus. The foam backing breaks down so you cannot reglue it and have it look any good.
    Jul 2003
    ......The foam backing breaks down so you cannot reglue it and have it look any good.
    Yes, yes and yes again.
    It will last about a day or two.
    I have half a can of spray adhesive leftover that I can donate to anyone who really wants to try it.
    Mahn England
    Ex 300Tdi Disco:
    Jun 2010
    Karratha W.A.
    When my mate did mine we removed all the foam and used about four litres of contact adesive didnt work as well as it could of previous owner tried to fix it with super glue and ruined the backing only way too do it properly is remove the whole thing from the car and dont skimp on the glue
    It'sNotWorthComplaining! Guest
    pinch some of the misses sewing pins, stick them in and this will GIVE YOU A TEMPORY HOLD.tidy it up and not have it dangling on your head.
    Then when you get around to it pull it all off clean the powdery glue foam from it and spend as little a couple hundred bucks at a motor trimmer and it will n look as good as factory.
    A search will show that it has been covered many times.
    May 2006
    Woolgoolga
    Quote Originally Posted by one_iota View Post
    and i have another, that'll make a whole can.
    waste of time
    May 2009
    Tatura, Vic
    I can also add half a can. I had a quote of $150 if I removed it. If you have it removed why would you bother trying to glue it when it can be done properly for 150 bucks?
    Dave.
