Well after 3 months I finally finished this little project
After fitting the gas tank on the drivers side I was going to get a tank custom made for the passenger side. But this tank came up for a 5th of the price it would have cost to have one made.
Lots of pics.
Firstly you need:
The tank
The gauge
(Thanks to bee utey)
The filler
The pre filter
The diverter valve
Light Truck 6-Port Motor Driven Valve on Pollak
Now comes the fun parts
Fitting sender to tank:
Gasket cut
Hole cut and sender fitted
Hole cut in Landy
Tank fitted to Landy
Pre filter mounted
Gauge and built in transfer switch fitted
Note. top gauge is diesel, bottom gauge is LPG
Diverter fitted
Tank filler plumbed (I plan on having a guard folded up for this, the false floor hides the top of the tank)
Pre filter plumbed
Fuel lines hooked up to the engine supply lines
Reverse polarity relay (required to be able to use an on-off switch, rather than using an on-off-on switch)
And lastly the filler cap fitted with standard Defender locking cap
All done, I can now understand why ARB sting so much to make these things up
I plan on having another tank made up that will sit in the well between the mudguards. One day .....
Any questions sing out
