Page 1 of 6 123 ... LastLast
Results 1 to 10 of 53
Thread: 19" Scorpion ATRs fitted on the D4 today.
    May 2010
    Brisbane, QLD, Australia
    First impressions....they look great. Far more robust looking than the OEMs....far more capable looking too.
    Only driven a few Ks on the road....they feel different....not better, just different...I'll have to put my finger on that. Pretty smooth and quiet though.
    On the technical side.....the boys fitting them had a mis-hap. It's never been mentioned on this site (that I've read)...but do you need to remove the tow hitch to get the spare in with a Scorpion fitted (standard size)? You didn't have to with the Wrangler....I can attest to that....I've changed three in the last week!
    But the guys broke the winch/cable assembly that retracts the spare, as it got stuck on the tow-hitch....even though I'd told them the key was in the glovebox.
    So that leads me to these questions:
    • Did they screw up or is the added tread on the ATR the problem? Well yes they screwed up, as they obviously tried to force it, but can it be done with the standard hitch in place?
    • If so (as in the diameter has changed), it must have affected my speedo...right?
    Thanks in advance.
    Kev.
    PS...Oh, yes....they are paying for the broken bits.
    May 2010
    Using the Spare Wheel Winch (Hot Tip)
    When using the spare wheel winch to either remove, refit & just wind up the cable (say when you throw the punctured wheel into the loadspace to be taken for repair) out of the way... You MUST have Tension on the cable at ALL times...otherwise the cables binds in the winder & jams.
    Just cut this, from the FAQs...
    Was aware of this and briefed the guy before he touched the car. I changed 3 wheels in a week and tensioned the cable every time....no issue!
    Guess he forgot.....or forced the buggery out of it trying to get the wheel past the tow-hitch......
    Cheers.
    Kev.
    Hi Kev,
    was going to get back & let you know but you beat me too it. Have had a week that nearly every 2nd customer that walks in has said the same thing, hence why i thought i would just do a quick tip.
    With regard to the wheel not fitting on std size into the spare wheel cavity, that an interesting one, It "Should" just fit in, regardless whether the tow hitch is in place or not...
    Strange one that..
    Jan 2010
    Edmonton Alberta Canada
    Diameters near the same for HP and ATR
    I looked up the calculated diameters for the Good Year Wrangler HP 255 55 R19 at 30.0" and for the ATR, 30.3" so that is effectively the same.
    I suppose your HP's were worn so the OD would be a bit less and the ATR's could be a bit bigger as well since they are brand new. My guess is however, that since the guys destroyed the winch, that they may be happier working on Tractor Trailer units where a bigger sludge hammer is always the first solution.
    I might add however that I watched an Audi mechanic trying to get my Land Rover factory spare, (the funny one), up back into the wheel well. To his credit, rather than fight it, after some struggle, he removed the winch, took it apart, found it to be OK, lubricated it a bit, and then reinstalled.
    Then he got a helper and together, the two of them got it up into the well. Since then I have never dropped it down, but always tied a full sized spare into the rear area.
    I still have the exhaust shield installed; I know some have removed it to get more space and some remove a rubber donut thing just to the underside of the winch location to get more space - me not.
    May 2010
    Quote Originally Posted by sniegy View Post
    Hi Kev,
    Strange one that..
    That's no worries mate.
    I wasn't there, so I have no idea what he has done. Anyway, I've talked to the owner...who's a good guy, and he knows that if he can't get it working, he's on the hook for a new one.
    Of course I'll test it multiple times before accepting that it's fixed.
    Do you know anything about the Tight Tolerence Mode? Some folks think it's not neccesary for a D4 alignment...just put it in 'Normal' height.
    Regards,
    Kev.
    May 2010
    Quote Originally Posted by bbyer View Post
    Thanks mate. Good to know he shouldn't have had any issue with it...I was concerned that I'd given him false info regarding not needing to remove the hitch (with a different type of tyre than the Wrangler). But in my defence...he had the key for the hitch, my wife had already told him where it was.
    If it fits no worries, I won't be removing anything either.
    Kev.
    Sep 2010
    Your tyre should fit fine...I've just fitted Cooper LTZ's in a 265/70/17 size which is approximately 40mm bigger than those that came with my 2.7D4.
    The trick is bend the exhaust guards back a little, drop some pressure out of the spare (mines at 15PSI) and use a bit of soap on all the points that touch. Then as you wind it up, as it starts to meet all the points in which it touches push the wheel upwards towards the back near the exhaust pipes. Following this method and doing it a little bit at a time I've got the brand new spare which is quite a bit bigger sitting in the factory spot
    I stopped the tyre guys doing it luckily as they were in the process of just cranking the winder despite it not going
    Hope this helps...
    May 2010
    Quote Originally Posted by OzAd4x4 View Post
    Hope this helps...
    Thanks mate, I guess I'll find out at 8am tomorrow.
    Kev.
    Aug 2010
    You sure they are LTZ Zions? I thought they only did 18's, 20's, 22's & 24's!
    Dec 2010
    Usually a Balmain Bulldozer
    my silent armours 265/60/R18 wont fit in the spare area unless i remove the hitch.
    Petre
