Results 1 to 10 of 18
Thread: Bi-Xenon lights: Aiming
    Disomania Guest
    After a minor altercation last year (truck reversed into the front, destroyed bonnet and bumper), I have not driven the D4 in any really unlighted conditions at night. There has always been street lighting, or a full moon.
    My son borrowed the car and went down the coast and rang complaining that the light was poor. Checking the car on the garage door when he got home, they appear aimed a lot lower than before. After the the repair, the lights were not totaly tight and I had to force the retaining clips back to there 'locked' position.
    Now, I've been told by some friends who say the 'know' that according to an ADR the xenons MUST self level - never seen it in the D4, but they do in the Golf GTi.
    So. Experts. Do I need to adjust the lights or take the thing to LR to get the 'puter flashed to make them do it themselves?
    NSW SW Slopes
    The self-levelling mechanism is the air suspension! They are adjusted manually.
    While the lights on my RRS are good they are certainly no better than the halogens in my 101. Not sure the bi xenons are worth the extra complexity.
    garry
    Disomania Guest
    After a troll through the manual, how the hell do I adjust the lights? There's nothing I could find in there - just for the halogens there's supposed to be a switch near the fog light ones. Xenon's don't have that. Bloody LR.
    Sydney, Australia
    Take it back to the repairer.It should have all been done properly in th the first place.
    Mar 2010
    Peregian beach
    Don't know if this will help but my halogens have two white socket head plastic adjusters that can be seen on the rear of the headlamp when looking from the top. One is for left/right, one up/down. I just use an extended 8mm Allen key to adjust them
    See this file - has three Windows XPS files covering headlamp adjustment and levelling
    Nedlands, WA
    The ADR doesn't require self levelling. it does require cleaning, hence you should have headlamp washers.
    Jan 2010
    Forster NSW
    The Bi-Xenons use the same white plastic adjusters. A Phillips head screwdriver fits into them reasonably well and there's not a lot of resistance. It's a while since I played with them but from memory one of them can only be seen through a hole in the supporting frame directly above it. The system is pretty simple and tilts the whole light assembly up/down so the aim of your high-beam halogen fillers moves up/down at the same time.
    Disomania Guest
    Ill have a look tonight and see what I can do. Shouldn't be too hard. Or, I could just leave it to the dealer as the car is due for it's 36k service - bought it and had a free 'corporate' service plan thrown in that was for 12k servicing instead of the usual 24k. I'll get them to adjust them then. And enjoy the 2011 Freelander loaner that they will give me too
