Hi James,
Looks like a fairly comprehensive list of things you have there and from the sound of it a good background to work with as well.
Just a couple of things I'd add. You may already be aware and haven't listed them. If so, please take with the requisite grains of salt.
If you are looking at one of the early ones 2002-2004 be sure to check the operation of the tilt and reach motors on the steering column. The early ones have a nasty habit of jamming (particularly the tilt). Some were replaced under warranty (by a modified design unit) but IIRC only if they showed problems early. Ask the owner about it and test the travel up/down and in/out for yourself. These are not an expensive (comparatively) item to replace but are a pain to remove/install.
If you are looking at a diesel have a listen for any obvious whine (above and beyond the typical turbo whoosh noises). Some of the earlier build models had issues with the turbo. Some failed, others just kept working but got noisy. This is again an early build thing. The TDV8 and TDV6's don't have it, just the Td6.
You mention the dead pixels. Both the Instrument Cluster and the MID are prone to these problems. Seem to happen more often in our lovely hot climate than other parts of the world. The glue around the connecting ribbons melts. Getting a good electronics tech to repair them is much cheaper than replacing the entire cluster or MID. About a quarter of the cost typically.
I can relate to holding out for "The One". Looked for almost a year. I found it at a QLD dealer but the bastard gazumped me and sold to a buyer from Perth. This was only after I asked him to send some photos of it to me. With no photos the vehicle had sat for three months in his lot unsold! Instead of sending the pics to me as asked he posted them on his website and strangely enough had lots of interest that very day. Used car dealers wonder why they have such a wretched reputation. I know why!!
Not at all happy about that little episode. Righteously ****ed off actually. It was Rimini Red with Sand interior. Only seen five red ones and only two of those with the Sand interior in all the years the L322 has been available. Yep, I need to get out more
. Hurt enough over that experience I compromised and found one with all I wanted/needed but not my first body colour choice.
BTW If the buyer is out there on this forum and reading this post, please be aware that I bear you no ill will. I am seriously disgruntled at the behaviour of the dealer though.
Happy hunting.
Iain
Iain
VK3BIT
03MY Range Rover HSE Td6
Nudge Bar, Sat-Nav, Cargo Barrier, IC-450, IC-706 and Codan 9350, DT-90 DBS, Chipped!
LROCV DTU member
