Results 1 to 8 of 8
Thread: Noisy transfercase
    Jun 2011
    Wyalkatchem
    Noisy transfercase
    Hi all
    first time disco2 owner , not a fan yet.
    i think my transfercase needs re building or repair it has started wining over 60km,i have checked and change oil and found the drain plug magnet was fery.
    can anyone recommend a repairer in perth please
    Dec 2010
    Brisbane Bayside
    I had a TDI D1 for 6 years and the transfer case would sing along over 50kms/h, never failed though. Depends how big the chunks are on the magnet. Might need new oil. 80w90 might help to save some money!
    BIG O
    03 D2 TD5 AUTO
    99 D2 TD5 AUTO ACE
    94 D1 TDI 3 DOOR (GONE)
    Jun 2011
    Wyalkatchem
    Thanks but i just put new 80-90 in and no difference.
    magnet was fury but no big chunks
    Mack Guest
    transfere case whine
    Hi My d2, 2001, 200k km was making a decent opera singing whine, and although not a fix i added a can of liqui moly lube to the case. It was a dramatic improvement, i have done over 10k now and it is still a lot ,lot quieter. I did email the german company first and asked them if it was of and they said it was. I realise one day that i will have to do something, but that day is no longer close enough to hear.
    Jun 2010
    Hobart, TAS
    Transfer gear whine is pretty normal for discos. Have had 2 now and both the same. Gear whine is acceptable, if it is growly rough noise then your bearings may need attention.
    Avoca Beach
    Hi all
    It depends what you are used to. If you have driven a (say Japanese) 4WD with a chain drive transfer then an LT230 will always appear rough and whiny with clunks on power reversal.
    I had a colleague who had 2 D2 transfer cases under warranty and both were no "improvement".
    This is part of the joy of a gear driven transfer.
    "Furry" does not really matter as there is always a bit of wear on the gears.
    "Chunky" is a problem.
    wait until you have it in low range and stop and it rocks backwards and forwards on the gears kachunk, kachunk , Kachunk.
    Regards Philip A
    Jun 2011
    Wyalkatchem
    Hi
    I ended up driving it for another 2 months waiting for the repairer and i was told it was close to destroying itself.
    So it depends if its a noisy trany or the bearings are trying to get out.
    Avoca Beach
    I didn't realise it was such an old post! How many pages back did the recent poster go LOL?
    AND was it much quieter after being fixed?
    Regards Philip A
