Results 1 to 10 of 16
Thread: Range Rover P38 Dash Removal Brisbane
    p38xtreme Guest
    Hi,
    I have a 1995 Hse 4.6 chipped with stormer 20 inch wheels.Drives great car in good condition.However the heater core went a year ago so I bypassed that with some accesories from Bunnings.Now my aircon evaporator has a leak .Has anyone in Brisbane had there blend motors ,evaporator and heater core replaced ?If so who by and were the happy with the job.I intend to keep the car at least another three years.
    Regards P38 xtreme
    It's a fairly substantial job but from this: evaporator
    it looks the best way to approach it. Put the whole dash on the bench.
    I've replaced the dashtop on mine like this: Dash Removal and Replacement (Range Rover 4.0/4.6/p38)
    and did the blend motors and heater core at the same time.
    As I had the heater completely out, I could have replaced the evap if needed.
    Mar 2009
    Bexley NSW 2207
    you could try a sealer for the evaporator. Wurth do a product which they claim seals ac leaks permanently.
    95 p38 dash boards can be a nightmare, as the SRS loom is in one piece and runs from under the cubby box, through the dash frame and ends up behind the head lights. sometimes it is easier to remove just the dash skin, leaving the 2 parts of the frame in situe, then dismantle the 2 halves of the heater/ac box.(8 hours instead of 16).
    Good point Rupert.
    When I did mine, after removing the top skin (to fit a new one), I found it easy to remove the heater box leaving the evaporator in place.
    p38xtreme Guest
    Quote Originally Posted by Rupert Prior View Post
    Thanks Rupert,will investigate the wurth sealer.If I could find someone in Brisbane who can do it in 8 hours I would get them to do it.
    Regards p38 xtreme
    p38xtreme Guest
    Dash Removal p38 brisbane
    Hi ,
    new to posting threads but appreciate anyone's views on who to send a P38 rangie in Brisbane to have the heater core ,blend motors and evaporator replaced
    Regards P 38 Xtreme
    Sandgate, Brisbane
    mrautomotive - Home
    These guys are in Redcliffe.
    There's another mob at Bowen Hills but I can't remember there names.
    Threads merged. Don't post the same question in multiple areas.
    Oct 2010
    Carindale, Brisbane, Qld
    I agree. MR automotive in Redcliffe are a good option. They know LRs. Dont know many other good operators in Brissy (yet).
    Now: 2005 L322 Vogue 4.4 M62TU (Black)
    Before: 2000 P38A HSE 4.6 - stately capability | 2008 Kluger KX-S | 2004 Forester | 2000 Yamaha XJR1300 | 1993 VR Calais | 1974 HQ Statesman - 308 V8 | HT | HK
    Maybe I should point a bloke on RRNET to MR. He was quoted $800 labour by a Brissie dealer to change the broken door mirror on his L322 Autobiography - the mirror with video camera costs $3200! That's four thousand dollars all up!
