I have VMS Mud Maps on my iPhone4, and slowly beginning to appreciate what they do/dont offer. I presume it would all operate same on the iPad?? Anyway, two things struck me: first, the system basically seems to work by simply placing your current GPS position over the (equivalent to scanned paper) map that is stored in the memory - of course its more smick than that - rectified etc - but basically thats how it seems to work. Second; there is no high level option to help you navigate in a normal drill down way to the map sheet you want from all of the sheets you have stored in your system. I have about 25 sheets, and have to remember which file name to use for each specific area, then call that one up from the menu list. All a bit limiting. maps themselves are great once you are locked in.
All said; Mud Maps have a new much better sounding interface out right now for beta testing, and I am hoping it will more or less solve all this above.
I suggest check where they are up to with the beta version.
					 iPad - Memory Map vs Mud Map/VMS
