Thread: P38 dashboard cleanup
    Would appreciate advice on how to remove abrasion/slight scratches in the finish on the trim section immediately below the central vents /above the Cruise/EAS switch panel..
    Hoges
    Mar 2011
    Hi Hoges,
    I have a friend who had a dash that was scuffed and slight abrasions as well as fading.
    Take the most extremely fine wetndry sandpaper and lightly ( very lightly ) take off any roughness, make certain that the papare is always wet.
    Once done and to your satisfaction, apply Meguires Gold Class Trim Detailer...( about $20 in auto shops ( Bursons ) and rub in. It brings a lightly oiled look but also it brings the colour back. I think the more applications you use, the scratches etc eventually will get filled in with the Meguires. But it is very good also for bring back your bumpers, trim etc etc back to new
    Oct 2010
    Carindale, Brisbane, Qld
    Hoges, I have two coming from UK (must be on a paddle steamer), when they arrive if they are in good nic I will let you know.
    Now: 2005 L322 Vogue 4.4 M62TU (Black)
    Before: 2000 P38A HSE 4.6 - stately capability | 2008 Kluger KX-S | 2004 Forester | 2000 Yamaha XJR1300 | 1993 VR Calais | 1974 HQ Statesman - 308 V8 | HT | HK
    Hi Glen, thanks for that ... it's not "real" bad ... just enough to annoy.. PM sent
    thanks 98se40..will try the Meguire's treatment also.
    May 2008
    Let us know how you go with the clean-up Hoges. My missus commented that her "Rosie the Rangie" (so much for the Hard Range Black Label Edition ) has some scratches there too.
    I think the centre console on my blue P38 is a bit beyond repair... might have to get in to a bidding war with Hoges for one of Glen's
    Cheers, Paul.
    Coogee, South of Fremantle, WA
    If after all your deals are done and there is a top dash in one piece I would be interested. Dont mind about scratches digs fading etc just in one piece.
    Oct 2007
    Williamstown, Victoria
    Have you seen those wood trim kits?
    1996 - 2002 RANGE ROVER WOOD CARBON ALUM DASH TRIM KIT | eBay
    Might be an option, I've seen a couple installed and they do look great.
