replacing 200tdi conrod?
					Last weekend my son 'managed' to fill his 200tdi engine with water.
Today we have removed head, and discovered that piston 3 and 4 do not travel past the head like #2, #1 may be also an issue.
This means that it will be necessary to replace the conrods.
Pulled off the sump, and ladder frame looks to be restricting access to the rod retaining bolts etc.
Will it be necessary to remove the ladder frame before we can extract the pistons etc out the top?
I am hoping this has happened to someone else and you can help me avoid removing the engine from the 110.
				Michael T
2011 L322 Range Rover 4.4 TDV8 Vogue
Aussie '88 RR Tdi300 (+lpg), Auto (RIP ... now body removed after A pillar, chassis extension to 130 & fire tender tray.)
