Not sure if they are different, but the 77 has reverse gear to the left and forward up beside 1st.
Hi all
Just wondering how you tell the difference between the Lt77 gearbox and the R380. As i have a 95 Defender and they changed from the Lt77 to theR380 in 1995. My defender has a salsbury diff in the ass, if this helps.
Mine must be a R380 as reverse is below 5th gear
That it is
HiGang , would anyone be able to tell me the dimension differences between the 77 and 380 boxes including bellhousing
You've been a long time waiting for this answer.
The R380 is 30mm longer than the LT77. If you want to use your current prop shafts in a conversion, you can get a short bellhousing R380 from Ashcrofts in the UK. Not cheap to import but a reliable factory rebuilt one. Ashcroft Transmissions - Short Bellhousing R380
Diana
