Results 1 to 10 of 17
Thread: Recommended on-road tyre pressures
    Feb 2010
    Sutherland Shire, Sydney
    I'm curious about the differential between the front and rear tyre pressure recommendations on the tyre placard on the B pillar in my 110 Puma wagon the rear pressures. The recommended pressure for the front tyres is 30psi and for the rear it is 45psi when lightly loaded.
    I haven’t had the car on a weigh bridge but I would not have thought that the weight distribution would be skewed to the rear although I may be wrong. Does anyone know why LR would recommend such a marked difference between pressures?
    Gosnells
    My '95 Classic is similar, (withouty pulling the bonnet and looking...) around 28 psi front and 38 psi rear. - Same or similar ratio, loaded/unloaded.
    When I bought it at 150K, the pressures were close to being equal... and my Viscous coupling died some months later. Can't say if the two are linked, though I suspect the ratio front/rear has a lot to do with the VC's life-span.
    in the wild New England, NSW
    Quote Originally Posted by RVR110 View Post
    I think you'll find that users of older 110s and deefers generally use substantially lower pressures than those placarded; (for comfort reasons). I know I do.
    I imagine that if you experiment with sealed road pressures of 30psi or slightly less all round you may find it more comfortable. Off the tar you may wish to decrease them even further.
    I believe that the 45psi is placarded to allow for the massive load carrying capability of the vehicle (which is rarely used)
    the Puma has, a version of the LT230 tc so no VC to worry about as in post #2
    Jul 2008
    Camperdown,Vic
    Hi, "The Land Rover Experience' by Tom Sheppard recommends:
    Kerb weight(unloaded) 26psi f and 30psi rear
    Max load: 27 front 48 rear
    You could use the 4psi rule to fine tune. Pressure should increase by 4psi from cold to warm after a run. If less reduce pressure; if higher increase.
    Hope this may be of use. Cheers.
    Aug 2009
    Kilkivan
    Recommended on road tyre pressures
    I'm running 26psi front and 28 rear on bitumen, unladen. I have the original tyres and my vehicle has done 18k. I find the recommended pressures make for a harsh ride.
    I am aware of a number of rollovers where Rovers have had tyre pressures low in stone and sand conditions.
    It seems that tubeless tyre beads can come away from the rim if under inflated and subject to high side load as in a sharp turn.
    For unmade roads and for a loaded vehicle I think it is prudent to increase pressures up to 28front and 48 rear depending on the load and conditions.
    My original tyres are wearing well and I would be interested to hear what mileages are being obtained with them.
    Apr 2010
    Connolly, WA
    I'm with you guys on the lower pressures. Guys spend a fortune on suspension upgrades where 26 and 28 Psi fixes all but the biggest issues on the ride. I personally use 1.8 bar (26 Psi) in the front, 2 bar (29 Psi) in the rear unladen, and 2.2 bar (32 Psi) in the rear under laden conditions (my personal guidelines for a Defender 90). I have in over 20 years of Landrover driving (civil Engineering and road building) never torn a sidewall sticking to these pressures. 110 and 130 drivers needs to find an optimum for the rear, but I do not agree with the blanket 40Psi rule (front and rear) that seems to be the standard out here in Northwest Australia.
    Rollovers with low pressures would be driver error, especially on rock. When you are crawling (as you should in rock) you often get pretty severe articulation that can result in "bounce". If your tyres are rock hard, the equal/opposite force thing comes into play and a rollover is most likely. Soft tyres (not so soft to break beads and pinch sidewalls) will cusion impact, mould over all but the sharpest rocks and generally give you better grip. A sidewall will damage much easier when rock hard than when it's able to "give" when a rock pushes against it. Obviously unnesesary wheel spin will negate this theory and cut your sidewalls to pieces, hence Low 1st in rock!
    This has worked for me over the years and there would be supporters of the other side of the coin.
    Cheers!
    South Yundreup,WA.
    And you guys find it comfortable to drive at sub 30psi front tyre pressures?
    I find at around this the front tyres get very squishy on the road at 110kmph and they wear uneven. Also fuel economy gets worse marginally.
    I usually run around 40psi rear and around 38 front.
    Not disagreeing, but it may depend on tyres too.
    2011 Discovery 4 TDV6
    2009 DRZ400E Suzuki
    2003 WK Holden Statesman
    Departed
    98 Ducati 900SS Gone & Missed
    Facta Non Verba
    LouisW Guest
    Quote Originally Posted by Loubrey View Post
    Cheers!
    Lou,
    I found "Betty" face a very harsh low profile sport car drive on JLR press guide - so I lowered to your suggested 26F 29R - The ride is far better (nearly comfortable
    however my tyre size are R18 - 265/65 any comment on this???
    Regards Louis
    Jul 2012
    ferntree gully australia
    I think the best thing you can do is try different pressures , ones that suits you ! For example 28psi front and 35psi rear , if most of the time you running empty .You will get to feel what you like , breaking ,wet dry , cornering ect. You can always put a bit more in , or take It out . When I go off road I always let my tyres down , then put them back up once on sealed road . I don't think It is an exact science , different tyres behave different at the same pressure !!.. Jim
    alien's Avatar
    alien is offline A Keeper of the TGO Silver Subscriber
    Bacchus Marsh Vic.
    Brace yourselves for what I run
    110 with loaded draws, roof rack and bulbar with winch.
    Defender and van on BFG Km2 mud tyres.
    Rough axle weights on last trip, front 1.2ton, rear 1.8ton, van1.0.
    On the black stuff(80% is 100km/h zones)...
    110 only, front-42, rear 50.
    Towing, front 44, rear 58(van 44).
    On the dirt...
    110 only in slow play mode, front 24, rear 30.
    Towing, front 28, rear 36(van 28).
    This is set using the 4Psi rule(After 1 hour of driving a 2->4psi increase from cold).
    Any thing less on the black top leaves marks where the side walls contact the road when cornering
    The handling is also reduced significantly so risk of a high speed rollover increases.
    My concern with running lower starting pressures is it causes the side walls to flex more.
    This can end up overheating the tyre casing which can in some cases lead to side walls failing.
    This is often the cause of blow outs, often on longer high speed trips.
    Cheers, Kyle
    The Good Oil.
    When did you last visit?
