Results 1 to 10 of 11
Thread: Series Diesel Conversion
    Jun 2008
    Morpeth NSW
    Hi everyone,
    I have sourced a diesel motor I want o put in the series. I don't know much about it, only have a picture.
    How do you think the gearbox will hold up?
    Sam
    Oct 2010
    You might need a body lift to fit that under the bonnet.
    you might be able to use the gear box to adapt the existing engine to start it....
    Dec 2009
    Queensland (though occasionally elsewhere)
    I think I might have an adaptor plate for one of those lying around somewhere....
    Gearbox will be ok, but you will have to beef up the suspension
    Im assuming you plan on putting it into a 109..
    if yo are you're apples youve got the sals down the back...
    Logan ( Brisbane)
    WHATS WRONG IT WILL FIT
    If its a 109, I would put it in the cargo area, turn the gear box around a 180 deg and it should fit a lot easier than trying to put it under the bonnet. leave the raditator where it is You would have to change the length of both tail shafts though This way you would have the only rear engine landie most likley in the world.
    HODGO
    Davehoos Guest
    i was once at a clearance auction and a cat V16 with air compressor in a trailer.most of the trailers had twin layer of doors for sound proofing.one only had a roof so it went for scrap price.these air compressors had no air tanks.
    what you do is tow the trailer and fit an air/hydrolic or electric motor to the 109.then drop the trailer for shopping runs.
    Davehoos Guest
    last one i saw a photo of had it mounted crossway behind the cab.
    i think it was a 6cyl.i remember seeing loads of belts.
    Qld.
    Only suitable if it pumps out the required 52 BHP!
    2007 Defender 110
    1993 BMW R100LT
