Thread: PSU's
    May 2003
    On The Road
    PSU's
    When I built ROME I bought a good modular one,,
    but 3 years down the track, it seems hybrid PSU's are the go,,
    Plug in Video card cables and the rest are permanent.
    Any reason for this?
    bad connections?
    its the new Black?
    damo_s Guest
    Ive never heard of a hybrid PSU before.
    I think modular are still the go.
    Are you in the market for one?
    If so, i cant recommend corsair strongly enough. I had a HX-620, now i have a HX-850. They are great. Well built and the modular design is great.
    They also have a 7 year warranty, which is fantastic
    May 2003
    On The Road
    Quote Originally Posted by damo_s View Post
    Probably the only part of ROME thats still under warranty
    May 2003
    On The Road
    another PSU question,,
    any advantage single rail over quad rail??
    I really dont think you can buy a bad PSU these days,,
    Apr 2002
    Godwin Beach 4511
    32.43 MB
    quad rail should be superior i would think as it will have 4 separate circuits.
    but depends on how you plug em up and what your using i suppose.
    for a big times gamer like you a multiple rail should be better.
    2007 Discovery 3 SE7 TDV6 2.7
    2012 SZ Territory TX 2.7 TDCi
    Aug 2008
    Perth, WA
    You'd think so but not always
    Quote Originally Posted by incisor View Post
    You have to be careful at how many amps can be supplied over the 12v rails some very high end video cards require 40amps on a rail.
    I had to replace a high end power supply because i didn't bother reading the requirements had 6 12v rails which made it great for a server as it could run plenty of hard drives but it didn't provide enough amps on the 2 rails to run the GTX480 i had.
    Simply way to look at it is you want a high quality power supply with as many seperate rails as possible but make sure the pcie 12v rails supply enough amps for the video card
    Heres a good example of what I'm talking about despite having similar wattage
    http://www.pccasegear.com/index.php'...ducts_id=15097
    4 12v rails at 18A
    vs
    http://www.pccasegear.com/index.php'...ducts_id=13525
    which has a single 60A 12v rail
    May 2003
    On The Road
    for a big time gamer like you
    finally some respect--
