First service for a Puma in Australia is not due until 20 thousand km though an oil change is a good idea. While a service can be carried out by any qualified mechanic, it may make it much easier if the dealer does it if you have a warranty issue. First service (A Service) is little more than replace and top up fluids. If you are concerned that the service is not done properly or that there are issues that the dealer may not pick up, then go to a LR specialist to do a check and report for you rather than to do the work, then go to the dealer with the report.
KarlB
					 ........And for what actually gets done, I am not sure if its worth it.
