Results 1 to 10 of 15
Thread: not a landy,but a dunnydore question
    May 2006
    Ulverstone,TAS
    Hi all,
    A mate just bought a 99 vt dunnydore ute,V8 nmanual,not a bad beast to drive,but prefer my disco .
    Anyway,the aeriel was broken and we went and got a new one today to put it in. Got home,jacked the vehicle up,undid the wheel nuts and then tried to get the blasted wheel off.We tried every trick in the book to try and get the blasted wheel off, but it remains stuck-more like glued on.. grrrrrrrrrrrrrrrrr.
    Does anyone know of a way to get the wheel off,but was thinking it its happened to one,it will probably be all wheels that are stuck on.
    Its only done 186 thou,so the wheels probably havent been off since new.
    2014 Freelander SE TD4
    2003 Range Rover TD6
    92 disco tdi manual sold
    95 disco tdi auto gone
    Dec 2009
    Gold Coast, Qld
    Personally i'd lower it with the nuts backed off a turn and wobble the steering wheel but thats me.
    Avoca Beach
    It will be stuck on the centre spigot with most probably corrosion.
    Whack the tyre with a rubber mallet one side then the other etc , or get down and kick it from under, which is probably difficult.
    Once off, make sure you clean up the spigot and put some never seize on it before assembly.
    Regards Philip A
    May 2006
    Ulverstone,TAS
    Hi disco inferno,
    We couldnt even get the tyre to wobble on the spiggot,its like someone glued it on permanently
    disco gazza
    92 disco tdi
    Quote Originally Posted by disco gazza View Post
    Hi all,
    Does anyone know of a way to get the sxxxxx wheel off,but was thinking it its happened to one,it will probably be all wheels that are stuck on.
    Best lasting passenger tyres in history then
    Loosen wheel nuts a turn... Lower to ground...
    Reverse - Brake hard - Forward - Brake Hard - Wobble steering side to side...
    Its corroded to the centre spigot
    Safety Bay
    If you think getting the wheel off is hard wait till you try and replace the aeriel. Pat
    Put the wheel nuts back but don't tighten them fully. Drive around the block turning left and right to put some side loads on the wheel.
    Western Victoria
    Quote Originally Posted by PAT303 View Post
    What he said.
    Use a wire coat hanger.
    Brisbane, Inner East.
    Had to do this to my Falcon after the aerial was snapped off flush with the guard by a tumbleweed on the way to Winton. Half a day pulling the centre console out and putting it back as the lead is fixed to the antenna and plugs into the rear of the radio, and well concealed by all the panels and crap.
    I lost another one on another trip to a cockatoo and have not bothered to replace it. Too much trouble.
    URSUSMAJOR
    May 2006
    Ulverstone,TAS
    To Pat303,
    Thats the reason of getting the wheel off,to replace the aerial..................
    SO its going to be a bugger of a job huh......
    Think I'll leave it then.....!@!#@$(**^&%$$#@!$#@^%%(*&
    disco gazza
    92 disco tdi
