Results 1 to 10 of 22
Thread: Oil volume
    Feb 2010
    melbourne
    Oil volume
    Does anyone know how much oil I'm going to need for a oil and filter change on a puma.
    I can't seem to find it anywhere.
    dmdigital's Avatar
    Between 6L and 7L for a service fill. Also worth noting the dipstick shows 2L between empty and full.
    in the wild New England, NSW
    from the castrol site:
    Castrol Australia - NetLube
    6.3 litres apparently
    Lube Reference Guide Quick Search
    LAND ROVER
    Defender Series, 2.4 Litre Turbo Diesel, Man., 4x4 (2007-2011)
    CRANKCASE
    CASTROL EDGE SPORT 0W-40
    Castrol EDGE Sport 0W-40 is Castrol's best. It is a full synthetic, SAE 0W-40, API SM/CF, ACEA A3/B3/B4/C2,C3 engine oil, formulated for high performance and prestige vehicles. The exceptional characteristics of this free flowing oil reduces friction and delivers ultimate wear protection and optimum engine performance right from start-up. Its formulation is extreme tested to deliver maximum horsepower up to 45% longer than other synthetic oils.
    Service Refill Capacity: 6.3* Litres.
    See note 499 below.
    MANUAL TRANSMISSION
    Refer to Dealer
    Service Refill Capacity: 2.4 Litres.
    See note 628 below.
    TonyC is offline Wizard Silver Subscriber
    NE Victoria
    32.83 MB
    Quote Originally Posted by 87County View Post
    LAND ROVER
    CRANKCASE
    See note 499 below.
    MANUAL TRANSMISSION
    Refer to Dealer
    See note 628 below.
    Well on that note can there be any other oil to use
    Tony
    dmdigital's Avatar
    Also you can use your wheel spanner to undo the cover on the oil filter (or a 27mm socket)
    Oct 2011
    Hastings, East Sussex, UK
    Topex says 7 litres of 5w/30 semi synthetic.
    May 2009
    Quote Originally Posted by Terrain Vehicles View Post
    Penrite HPR Diesel 5 meets
    Ford M2C153-G/H - This one actually is a Fully Synthetic spec and the HPR Semi meets it!
    M2C171-C
    Ford M2C-913-B
    One of those is for the TDV6 in the RR and Disco3/4.
    So i gather it should be easily suitable for a 4 pot ford transit engine.
    Oct 2011
    We have always used the same 5w/30 oil for all engines. I don't think you need to be too fussy over it. Just so long as it's good quality.
    Kingston, Tassie, OZ.
    6.5 litres, we just use Either Helix 5w40, or Valvoline Synpower 5w40. Interesting Rick about the HPR5 Diesel, may look into that as it is cheaper than the full synthetics, can maybe use that in un chipped and quietly driven Td5's?
    JC
    Apr 2010
    Connolly, WA
    Obviously not had the joy to deal with the organisation known as Land Rover Australia...
    Considering the harsh conditions (ambient temperatures dust and continued off road work rate) we need to change oil often and use what LRA specify. Should you suffer an engine failure of any description they will take oil samples and if your oil is a fraction out of specification they will not honour warranty repair...
