Results 1 to 9 of 9
Thread: Changing van wheel/tyre
    May 2008
    Avonside NSW
    Hi All
    I too am changing a six stud hub on the van to a five stud.
    The D2 has a 7Jx16 wheel with a 235/70/16 tyre (alloy)
    The van has a 15x6.5 JJ wheel with a 235/75/15 tyre
    Ive purchased 8 steel wheels 16 x 7
    What would you suggested as tyre size.
    I have no idea of what we are talking about so little words would be appreciated
    thanks
    mat
    Sep 2010
    melton, vic
    225/75/16 not a bad size good load rate and speed ie which brand you go
    Jul 2007
    Quote Originally Posted by Jedimastermat View Post
    Hi All
    thanks
    mat
    I'd suggest you go for a wheel and tyre you can use on your tow vehicle otherwise thre is little point in changing the stud pattern and wheel size on your van.
    Ellendale Tasmania.
    You've got excactly what you need, all you need now are Commodore braked hubs for the van,(I'm assuming your van has brakes) Commodore hubs are the same PCD as the D2 of 120 PCD.
    Have them fit 9/16 wheel studs to the Commodore hubs (most trailer places won't fit M14 studs) as you steel rims it won't matter about wheel nuts, you'll just need to carry spare M14 for the car and 9/16 for the van.
    You can run the same 235/70/16s on the van, the 235/75/15 that are on the van are 28.9", the D2s tyres of 235/70/16 are 29.0", so you should have no problem running the D2 steel rims and tyres.
    Baz.
    Cheers Baz.
    2007 BMW R1200GS
    Don't quite understand why one would use 9/16" studs... If you fit Commodore studs you have total compatibilty with the D2...
    Ellendale Tasmania.
    Quote Originally Posted by Hoges View Post
    I tried to get a few trailer places fit M14 studs when I changed my trailer to suit my D2, all of them would not fit M14 studs, the other thing is, all Commodore brake hubs of the shelf come with 1/2 studs or 9/16 studs, also only the late model Commodores have 14mm studs and I'm pretty sure the trailer places haven't caught up yet and still use imperial studs, unless things have changed.
    What I did was do it myself, bought the Commodore hubs, knocked out the 1/2 studs and re-drilled to suit the 14mm studs, at the time it was all I could do to get what I wanted, even ALCO wouldn't fit 14mm studs when I asked, they said they would only fit 9/16 studs.
    If you know a place that will supply Commodore brake hubs with 14mm studs, please let me know, cause I'll buy a pair now, I'm changing to electric brakes and buying them without having to re-drill them myself would be a heap better.
    Baz.
    Cheers Baz.
    2007 BMW R1200GS
    May 2003
    On The Road
    with you and the tardis on board you may need these---
    Couplemate Trailer Parts
    x2! "Steve" @ Couplermate drilled the Alko 10"drums to the Commodore PCD and fitted the M14 studs I supplied (from Holden dealer parts). Remember: DO NOT try and do up the wheel without a 10mm spacer... otherwise you run out of room on the threaded portion of the stud which will protrude and damage the outer covering on the OEM LR wheel nut... You should be able to buy the spacers from Autobarn ...
    May 2008
    Avonside NSW
    Thank you
    http://www.aulro.com/app/uploads/17416/DSCF1961.JPG
    http://www.aulro.com/app/uploads/17416/DSCF1965.JPG
    Thanks All
    I have the the hubs, studs, elecric brakes, yes it has 10" ones and its getting a 65mm square axle up from the 40mm. All sorted, hopefully. I believe they are off the shelf bits as they were punching in part numbers from a catalogue. Where I bought the van will do the work for me. Im not mechanically inclined, wish I was but seems Im not.
    Obviously going to do something with studs as they want the disco wheel nuts and a couple of shod wheels to sort out axle length.
    I just wanted to throw out there what is the biggest, widest tyres that I could fit. It seems thanks to your advice Im pretty close with as is. (Which is a shame as they look like they are a little small with the lift on D2).
    thanks again for info, slowly learning
    Mat
