Contact/PM Drivesafe as he sells a kit .
Regards Philip A
 D3 Caravan LED Lights - Issues
		Hi there, I have a D3 and have just got a caravan which has LED stop/driving/indicator lights. The issue is the LED Indicator Lights Flash (very faintly) all the time and the car doesnt recognise that a trailer is attached (I guess because there isnt much load electrical load with LED's as opposed to incandecent globes). Is there a fix I can do to rectify this or does anyone know if Land Rover sell a plug setup ? If they do.........any ideas what the part number is and how much $ ?? Im in Vic if it makes any diference ?
 Swaggie
						Subscriber
						Swaggie
						SubscriberContact/PM Drivesafe as he sells a kit .
Regards Philip A
Have you looked in the FAQ section?
http://www.aulro.com/afvb/d3-d4-rrs/...4-rrs-faq.html
There's a couple (or more) plug in devices available.
Below is a link to a current discussion of relays vs load resistors to resolve the LED concern.
DISCO3.CO.UK - View topic - LED trailer lights not compatible with Disco 3?
 Wizard
						Subscriber
						Wizard
						SubscriberI am also wishing to get a box for the Trailer LED Issue and my D4.
There appears to be 2 which I have found to be used.
Linear Electronic Design, LED Adaptor Module www.linearelectronicdesign.com/
LAB Electronics, PulseBusta Mk2 www.labtronx.com.au/
Is one better than the other?
Is there any difference the requirements between for a D3 and a D4?
NTB
Hi NTB,
I got one from Linearelectronicdesign a couple of years ago. I've done a bit of travelling, corrugations, wet, more corrugations, dust and oh did I mention corrugations, the unit is still fine, and works a treat. Not cheap but things that work usually aren't.
Easy to deal with all the usual stuff....... no problem at all.
Land Rover is supposed to have designed the D4 trailer hookup such that a LED trailer light setup does not require anything extra.
I also think that is one of the reasons the D4 now has the LED tail light assemblies - because the necessary alterations are now all designed in at the factory.
Not quite,
LR have designed the D4 to use LED's _on the vehicle_. The upshot is that there is no longer any intermittent pulsing of LED lights, whether on the vehicle or on a caravan/trailer plugged into the vehicle.
However, the car-specific trailer functions (trailer-assist, reverse-sensor overrides etc) still require incandescent globes, for them to be triggered successfully. For that you will still need a dummy load of some sort.
I'll add the caveat that some LED setups seem to trigger _some_ of the trailer functionality and not others. For instance, my old LED-fitted van did not trigger anything. With my new one fitted, the reverse sensors automatically disconnect (as they should), but nothing else seems to be triggered.
Gordon
 Fossicker
						Fossicker
						Hi i have both the linear module and the pulse busta. The pulse busta is much better. Less trouble with car electrics. Regards Jim
