Results 1 to 10 of 16
Thread: D4 Alternator Question
    Ellendale Tasmania.
    I've done a search with no success, I was looking for the thread on how the D4 alternator works, it was posted that it stops charging at a certain speed, is it the 2,7l or 3.0l they were refering too
    Baz.
    Cheers Baz.
    2011 Discovery 4 SE 2.7L
    2007 BMW R1200GS
    1979 BMW R80/7
    1994 Yamaha XT225 Serow
    Padstow NSW
    it was both? i think, and its only supposed to charge when your off load (coasting)?
    the thread was a bit vague...
    in relation to what do you need to know about the alt?
    touch wood i havnt had any dramas with mine, it seams to do all thats
    required of it.
    cheers phil
    Aug 2008
    Sunshinecoast QLD
    Hey Baz
    If you have the touch screen/nav, you can put up the secret screen, and there is a section there for "Vechile Signals", which will give you voltages.
    Cheers Ken
    Queensland
    Hi Baz, the 2.7L’s alternator works like the D3.
    The 3.0L is the one that, after the initial boost charge when you first start the motor, the voltage goes down while the motor is under load and rises as the load reduces, such as when coasting.
    May 2010
    Southern Sydney
    I agree with the above. The only thing i can add is that after the initial charge the car will operate at different voltages while cruising. This may vary between as low as 12.3 and 14.7. I have observed this over some 12 months on my d4. I have no idea why. Could it be some sort of battery conditioning algorithm?
    Apr 2010
    sydney
    my 2011 2.7 D4 sits between 13.7 and 13.9 volts all the time. occasionally i see 14.0 or 14.1
    lucas
    Feb 2009
    Quote Originally Posted by roamer
    Hey Baz
    Cheers Ken
    Tell, tell! Where's the secret screen?
    Now 2016 D4 HSE 'Leo' and Steve the Triumph Speed Twin
    Then 2010 D4 3.0 HSE 'James'
    Then 2010 RRS TDV8 'Roger' w traxide DBS, UHF, Cooper Zeons, Superchips remap
    Then 2010 D4 TDV6 'Jumbo' w traxide DBS
    First love 2002 D2 TD5 'Disco Stu'
    Aug 2008
    Sunshinecoast QLD
    Quote Originally Posted by Stuart02 View Post
    If you have nav\touch screen, put it on Home Screen", there is a grey bar at the top, hold finger in centre of bar for 3sec,then hold finger at left hand side of bar (on H ) for 6 sec till it goes to code screen, code is 753.
    From there all sorts of stuff , bring camera on while on the move forward, Vehicle Signals, which oddly the speed reading is correct (ie not 5k\h fast like speedo).
    I think the varible alternator has to do with load on motor, hence drops down when under load to save fuel\lessen pollution (more reason for carbon tax rebate,yeah sure)
    Cheers Ken
    Maybe this should go in FAQ under cool stuff
    Ellendale Tasmania.
    Thanks everyone.
    Robert, maybe put this info in FAQ.
    Baz.
    Cheers Baz.
    2007 BMW R1200GS
    1979 BMW R80/7
    Sep 2011
    baldivis, WA
    Hi all
    Have had our Discovery for a month now and am constantly getting the low voltage stereo will turn off in 3 minutes thingy. We brought the vehicle home from Albany (4 odd hour drive) i would have thought the drive would have charged the vehicle battery enough not to get the warnings. I have since stuck my cteck 5 amp charger on and left it on for 2 days (took overnight to progress through the stages). Now i have just flicked my solar panel on the battery and the regulator today showed a SOC of 80%. I would have thought the Alternator would have done a better job of charging the battery. I would hate to go camping and leave the fridge on for a couple of days. My queries are does anyone have an understanding of how the alternator works. The so called secret screen just how exactly does this work as i have tried this evening to no avail. I have the black bar at the top of the screen.
    Steve
