                                                14th November 2011, 06:38 PM
			How much lift do I have?
					Hey guys, wondering if anyone can tell me how much lift i have on my 1985 90.
 Just been out and measured and the distances between the bottom of the standard bump stops and the bit on top of the diff it is designed to 'bump' into.
 Front 128mm av.
 Rear 168mm av
 Does anyone know how this compares to standard?
 Partly for curiosity and partly because i am thinking of bigger shoes.
 Thanks.
                                                14th November 2011, 07:53 PM
					IIRC stockers are somewhere from 65-75mm between the bump stops on the front, depending on hardware fitted.
                                                15th November 2011, 01:51 PM
					Thanks for that, so looks like i have 2 or 3 inch lift.  Going by the height at the rear and the fact there is a winch, bumer, chequer plate, steering guard weighing down the front I will assume it is 3".
 Which means 35s are possible, (it is a weekend toy and a 3.9efi V8 so practicality or loss of power due to gearing arent really an issue).  I just need to check that it would fit into the carpark of my building with an extra 1.5" height...
