Results 1 to 10 of 15
Thread: Diff lock light no worky
    VladTepes's Avatar
    Bracken Ridge, Qld
    Took the truck on some light off roading today and when i slipped her across into diff lock the light didnt come on. tried several times, while still and moving.
    So how do I tell whether the diff lock is actually engaging?
    Could it be as simple as a fuse? Which one, if so.
    gone
    1993 Defender 110 ute "Doris"
    1996 Discovery 1
    current
    ill have a go untill someone that actually knows comes along....find a drainage ditch, cross axle through it so you loose traction, engage difflock and see if that makes a difference.....if your still stuck...not engaged id say.
    Oct 2008
    Quote Originally Posted by VladTepes View Post
    Jack all 4 wheels off the ground or at least one wheel on each diff.
    With cdl on spin the front wheel and one of the rear wheels should turn too.
    There is also a sensor on the tc have a look at that and make sure it is plugged in and not full of mud and dust.
    Feb 2005
    Quote Originally Posted by uninformed View Post
    so how does he get out.......
    Jan 2009
    Samford
    I just had a laugh wondering the same thing.
    James.
    shhhhhhh....youll ruin the fun
    South Sydney
    It is so simple to check, jack one front wheel up or rear for that matter, lock the cdl, if the car tries to drive off the jack, then the cdl is working, we do this all the time when someone asks us to check a landrover for them. And it is probably a fuse anyway, unless the linkage is bent.
    swing on by on wednesday...
    VladTepes's Avatar
    Bracken Ridge, Qld
    TC ? No TC it's a 94 model 130 !
    Dave - On Wednesday I'll be in Bundaberg
    gone
    1996 Discovery 1
    current
    Oct 2008
    transfer case
