Thread: p38 starter motor replacement
    May 2010
    Spearwood WA
    DECIDE TO CHANGE MY STARTER MOTOR TODAY I HAD BEEN PUTTING THIS OFF FOR A WHILE BECAUSE THE LOCATION OF THE TOP BOLT. OK THIS IS HOW I WENT ABOUT IT . FIRST I REMOVED DRIVERS SIDE FRONT WHEEL AND THEN REMOVED THE PLASTIC INNER WHEEL ARCH LINER. AT THIS STAGE YOU CAN EASILY ACCESS THE STARTER MOTOR AND BOLTS USING A 5/16 HEX SOCKET . NOW FOR THOSE OF YOU WHO STILL HAVE THE EXHAUST SHIELDS IN PLACE THIS CAUSES I BIT MORE WORK AS THE OUTER SHIELD WILL HAVE TO BE REMOVED. I WAS A BIT LUCKY AS I DIDNT HAVE ANY OF THE OUTER SHIELDS STILL IN PLACE ONLY THE INNER ONES WHICH AFTER REMOVING ONE BOLT AND A LITTLE BIT OF BENDING I WAS ABLE TO GET MY HEX SOCKET AND 3/8 DRIVE RACHET IN THERE. I REMOVED ELECTRIC CABLES AND PLUG AFTER LOWERING IT DOWN . CONNECTED CABLES TO NEW ONE THEN LIFTED INTO PLACE.
    May 2008
    Hi P38driver - thanks for sharing the pics and your method.
    A bit hard to read all in CAPS LOCK though.
    Guessing that the first thing you did before going near the starter was to disconnect the battery
    I am worried about you driving around with the exhaust heat shield removed. The amount of heat generated is huge and may damage nearby plastic and rubber components.
    Cheers, Paul.
    Quote Originally Posted by p38driver View Post
    Socket or hex key?
    May 2010
    Spearwood WA
    Quote Originally Posted by PaulP38a View Post
    Cheers, Paul.
    i used a hex socket which is a socket with a allen key inserted in the end of it , regarding the heat shields the outer ones were missing when i bought the car 4 years ago , thanks for the replys .
    May 2010
    Spearwood WA
    Socket or hex key?
    I may have missed some very important information in my original post regarding starter motor replacement . Thanks for Paul for reminding me about the safety aspect when working on cars . Disconnecting battery when working on car electrics and always use jack stands when working under your car.
    i have attatched picture of hex socket used 5/16 x 3/8 drive for Rons info. Just one more thing about heat shields , has anybody had any problems driving around without them fitted ?.
    regards p38driver
    Last edited by p38driver; 15th December 2011 at 12:59 PM. Reason: replys from members
